Old 06-19-2007, 01:38 PM   #1 (permalink)
E-Chen's Avatar
Date registered: Jun 2007
Vehicle: 1999 S500
Send a message via AIM to E-Chen
Where are the horns located on the W140?
I was wondering if any of you guys and or gals could tell me where the car horns are located on our W140’s…and if the location of the horns differs from year to year (ex: 1992, 1993, 1998, 1999 and etc) also if the location differs from model to model (ex: S320, S420, S500 S600 and etc)? Note, I did locate one horn behind the front passenger headlight note sure what this horn is… is it the alarm horn?
Reason why I’m asking is because I’ve only had my 1999 S500 for five months so the location of things on the car are still new to me… with that being said I wanted to change/replace the horns on the vehicle including the alarm horn to Hella Supertone horns from Germany…these horns are constructed with black painted metal body, a red protective grille and a bracket for screw-mounting (300Hz Low Tone/500Hz High Tone).
1999 Mercedes-Benz S500
1999 Toyota 4Runner Limited
1968 Shelby GT500KR
1955 Porsche 550 Spyder (Next in line)
E-Chen is offline   Reply With Quote
Old 06-19-2007, 01:48 PM   #2 (permalink)
Date registered: Mar 2004
Vehicle: 1997 S600 sedan
Tucked inside the front bumper cover on the left and right sides. Horn behind the headlamp is the alarm horn.
Brett
Brett San Diego is online now   Reply With Quote
Old 06-19-2007, 01:52 PM   #3 (permalink)
Date registered: Dec 2002
Vehicle: 92 500SEL -01 E320T
The 92 to 95 horns are behind the bumper under the headlamps, if you take off the shield you can see them. The alarm is next to the radiator I think. It is a little crowded up there, I replaced a OEM with an OEM I have heard it is easier to remove the bumper, four bolts two in the grille with rubber bumpers, two in the lower panels covered in the vents. The bumper is held on the sides by a slide in bracket. It looks like a three handed job, maybe someone has done it.
Peter Guenther is offline   Reply With Quote
Old 06-19-2007, 05:21 PM   #4 (permalink)
MarkNissen's Avatar
Date registered: Nov 2006
Vehicle: '93 600 SEL
Originally Posted by Peter Guenther
... I have heard it is easier to remove the bumper, four bolts two in the grille with rubber bumpers, two in the lower panels covered in the vents. The bumper is held on the sides by a slide in bracket. It looks like a three handed job, maybe someone has done it.
I would be interested in anyone's experience with bumper removal, I'm going to do mine shortly
cheers
MarkNissen is offline   Reply With Quote
Old 06-20-2007, 10:29 PM   #5 (permalink)
Haku's Avatar
Vehicle: 1996 S320 Carlsson Obsidian Black
Send a message via MSN to Haku
What is this "alarm" of which everyone is speaking?
~ 1996 S320 ~
19" carlsson/lowered/crystal LED tails/crystal LED side markers/crystal indicators/S600 walnut steering wheel/S600 grille/anthracite black interior/sunroof
Haku is offline   Reply With Quote
Old 06-20-2007, 10:32 PM   #6 (permalink)
Vehicle: 1993 300SEL/S320
All US spec cars came with an alarm in them, mine didn't so I guess it might be an Asia spec thing, from what I hear in SIngapore atleast the punishment for dealing to someones car on the street is pretty high so alot were not fitted as there was no need.
NZ Benz is offline   Reply With Quote
Old 06-20-2007, 10:35 PM   #7 (permalink)
Haku's Avatar
I haven't noticed anything on mine - but then it didn't come with remote - what are some of the tell tale features if you have one - do you know? (aside from the extra horns I guess)
Old 06-20-2007, 10:39 PM   #8 (permalink)
Yup the door lock switch on the dash, if there is a little light in that like the rear window demister when it is on then the car has an alarm. I think it flashes when activated also try your vin in the Russian site:
Mercedes-Benz Club Russia | Mercedes-Benz / VIN
Got New Horns 123CLOCK W126 S,SE,SEC,SEL,SD,SDL Class 1 05-27-2007 10:44 PM
ML Horns marc00 W163 M-Class 4 04-03-2006 09:16 PM
horns 03-g500 G-Class 0 10-05-2004 08:46 PM
2 Horns ///S320 W140 S-Class 6 11-11-2003 03:08 AM
Goodbye wimpy ML horns, hello Hella air horns.... Drew W163 M-Class 33 09-04-2003 09:25 AM
