Replace Lower Control Arm or Bushings? - Mercedes-Benz Forum
post #1 of 35 (permalink) Old 06-06-2007, 10:51 AM Thread Starter
BudW's Avatar
My stealer told me I need to replace the lower control arm bushings. Says the $1,026 will make my ride smoother.
So in labor costs, would I be better off replacing the lower control arm or going to all the effort to knock out the bushing in the existing arm.
This remove/replace seems a less costly (cheaper) way to go.
I am assuming that a new lower control arm has the bushing made part of it. True or not true?
BudW
1993 500SEL
BudW is offline
post #2 of 35 (permalink) Old 06-06-2007, 11:09 AM
kutz's Avatar
Date registered: Apr 2005
Vehicle: 1995 S500
My lower control arms was snapping, the metal part so I had to replace it. My mech welded it so I can drive for a week until he got the part. Total cost was $600 CAD. If the control arms are not snapped then you can go ahead and change the bushings although I don't think the dealer will do that due to safety regulations.
kutz is offline
post #3 of 35 (permalink) Old 06-06-2007, 11:33 AM
gstate's Avatar
Date registered: Jul 2006
thats a lot of cash...probably a little less than what the benz is worth itself. I would go to another shop. Stealers are ridiculous, unless you have been in an accident and its the other guys fault
99 S500
gstate is offline
post #4 of 35 (permalink) Old 06-06-2007, 12:13 PM
MaximRick's Avatar
Date registered: Apr 2007
Vehicle: 1995 Silver S-320
that's far too expensive... get a few quotes at other places before you consider making a decision on it.
MaximRick is offline
post #5 of 35 (permalink) Old 06-06-2007, 12:26 PM
Date registered: Dec 2002
Vehicle: 92 500SEL to 01 E320T and others
Are the bushings bad? Why are you replacing them? There is a special tool to install them since they are hydraulic. I had mine done along with sway bar links, alignment, and steering damper at MB for less than $1,000. Did it make a difference, I dont know, the inherent vibration still occurs! It was a 6hr job!
BTW, the bushings are close to $100 for each side. I cant immagine what a whole control arm would be.
Peter Guenther is offline
post #6 of 35 (permalink) Old 06-06-2007, 12:29 PM
MaximRick's Avatar
went to the good old bill's to check something...i had to change the 2 rear bushings for the control arms. Parts cost $84, after labor it came out to about $214 ($80/h labor). Based on that if you can find out how much the parts for the control arm will cost just figure out labor/h and you'll know your price. (obviously depending on what shop you go to will change the price the most w/ labor rates)
post #7 of 35 (permalink) Old 06-06-2007, 01:43 PM
MarkNissen's Avatar
Date registered: Nov 2006
Vehicle: '93 600 SEL
BudW
1993 500SEL
Well, in NZ dollars, " lower control arm bushings" and a bunch of bushes in the front, 4 new brake rotors and sets of pads + brake shoes for the emergency brake, 1,800.00 which is about 1,300 US $. This, at a busy mechanic in the expensive part of town.
Stay away from the dealer, chooose a good busy firm near some euro car dealers
JMHO
Cheers
MarkNissen is offline
post #8 of 35 (permalink) Old 06-07-2007, 10:12 AM
Jonathan Wallin's Avatar
Date registered: Oct 2006
Vehicle: S600 C140 1994
BudW
1993 500SEL
I did it myself. It was'nt that hard. The springs were very powerful and took some time to compress.
Look here: http://www.benzworld.org/forums/w140...-bushings.html
~C140 S600~
http://www.garaget.org/?car=34361[/url]
Jonathan Wallin is offline
post #9 of 35 (permalink) Old 06-07-2007, 04:09 PM
Vehicle: 1993 300SEL (Sold) 2001 530i
Quoted: 8 Post(s)
JMHO
Cheers
I had my lower bushings done in 2005 cost me about $450 NZ for the bushings
NZ Benz is offline
post #10 of 35 (permalink) Old 06-07-2007, 06:37 PM
Date registered: Dec 2006
Vehicle: 1993 Mercedes-Benz 300SE & 1998 Mercedes-Benz C230
If they are a dealer, then they should have the factory tool to replace the bushings. I had mine replaced, but you need the tool to do it right, assuming of course the metal frame is still intact. The price seems too high though for a simple replacement bushing job on the lower control arms. Cheaper to replace the bushings.
dbmoylan is offline
    Replacement procedure for lower control arm bushings? brentslone W210 E-Class 11 04-16-2014 05:27 PM
    Replacing c240 lower control arm bushings? RayC240 The Discount Tire Direct Tire, Wheel, Brake & Suspension 1 08-31-2006 11:33 AM
    lower control arm bushings BenzNoob W210 E-Class 4 08-14-2006 10:06 AM
    control arm bushings/lower front nrv121803 W124 E,CE,D,TD Class 1 06-17-2005 05:45 AM
    Cracked lower control arm bushings HEX20 R170 SLK-Class 4 02-11-2004 02:20 PM
