» Site Navigation
» Other Sites
Old 02-08-2007, 01:18 PM   #1 (permalink)
Benzkid27's Avatar
Date registered: Jan 2007
Vehicle: 1994 S500
Rearview Mirror
I need JUST the cover for the rearview mirror..any places i could find one????
Benzkid27 is offline   Reply With Quote
Old 02-08-2007, 06:11 PM   #2 (permalink)
Date registered: Dec 2002
Vehicle: 92 500SEL -01 E320T
If the tabs broke you are dead meat, I drilled vey small holes just before the bend of the bracket. I then drilled very fine holes thru the back cover and used very fine screws to hold the back cover to the brackets. Its hard to describe...
Peter Guenther is online now   Reply With Quote
Old 02-08-2007, 06:20 PM   #3 (permalink)
miloking's Avatar
Date registered: Jun 2006
Vehicle: Current 1992 - 500SEL, W124 - 1989 230E (sold)
I use old solder iron to do little plastic welding and to weld toghether anything broken thats plastic and so far eveything is holding up fine (tail light cover, and some under bonner plastic parts), just and idea if you dont want to drill holes and those plastic tabs broke off ....
miloking is offline   Reply With Quote
Old 02-08-2007, 10:16 PM   #4 (permalink)
Vehicle: 1993 300SEL/S320
Now that is some good No.8 wire stuff! I feel kinda bad using duct tape on the dist cap cover on my engine.
NZ Benz is offline   Reply With Quote
Old 02-08-2007, 10:31 PM   #5 (permalink)
miloking's Avatar
yeh just make sure you do the welding from the inside so you dont ruin the look, normaly i first duck tape the parts together on the side that i wont be welding and then make couple quick welds across the crack and then follow the crack but being careful not to melt the plastic all the way thru but enough to allow it to join together....hope that helps to fix you plastic cover ;-)
Old 02-08-2007, 10:34 PM   #6 (permalink)
Yea it should when I get round to it, I just finished cleaning me engine bay too, that might be something to take pics of with my new camera.
Rearview Mirror bktejas W203 C-Class 1 02-22-2007 04:33 AM
Rearview Mirror biggy R129 SL Class 5 01-12-2007 06:31 AM
Outside Rearview Mirror Benz06 W203 C-Class 1 04-14-2006 09:53 PM
RearView mirror Mr2weenie W140 S-Class 4 01-12-2006 01:53 PM
Rearview Mirror hansduker W163 M-Class 2 10-17-2005 12:11 PM
