How to refill transmission oil - Mercedes-Benz Forum
post #1 of 7 (permalink) Old 01-21-2007, 08:51 PM Thread Starter
Date registered: Nov 2005
Vehicle: 92 600 SEL
Quoted: 2 Post(s)
Hi all,
Recently I had to do some radiator work and lost a little transmission fluid thru the cooling lines. Does anybody happen to know how to refill the oil? How do I check the level? I understand there's a filter for tranny, does that need to be changed? Thanks.
qha000 is offline
post #2 of 7 (permalink) Old 01-22-2007, 11:19 AM
canadian600's Avatar
Date registered: Aug 2006
Vehicle: 1993 S600 Lorinser
It is a very good idea to change your tranny filter - should theoretically be done everytime you have a tranny service. As for filling, I am not 100% sure - hopefully someone else can chime in on that one...
canadian600 is offline
post #3 of 7 (permalink) Old 01-22-2007, 12:06 PM
Date registered: Mar 2004
Vehicle: 1997 S600 (sold)
Quoted: 14 Post(s)
For my 1997 S600, you fill through the dipstick tube. My transmission is different from yours, however. But, many transmissions get filled through the dipstick tube.
Brett
Brett San Diego is offline
post #4 of 7 (permalink) Old 01-22-2007, 02:37 PM
gartracescort's Avatar
Date registered: Nov 2006
Vehicle: W639 Vito 110 CDI; Ponton 220S; VW Phaeton V10 tdi; 1995 S500 ex diplomatic car (gone)
That's right, and check the level with the engine running after a short drive having used both forward and reverse. Careful not to overfill as the level goes up faster than you would expect.
gartracescort is offline
post #5 of 7 (permalink) Old 01-22-2007, 04:15 PM
kutz's Avatar
Date registered: Apr 2005
Vehicle: 1995 S500
Yep, the dipstick tube. It's in the rear of the engine at least on the 500. It will say something like only a licensed MB tech should take off the dipstick for the trans fluid.
kutz is offline
post #6 of 7 (permalink) Old 01-22-2007, 05:44 PM
Date registered: Jul 2004
Quoted: 312 Post(s)
Fluid level is checked on a level surface, with the car running in park, at operating temperature, clean lint-free cloth to wipe the dipstick, add through the dipstick, careful not to overfill.
deanyel is online now
post #7 of 7 (permalink) Old 01-25-2007, 06:34 AM Thread Starter
Vehicle: 92 600 SEL
Quoted: 2 Post(s)
Thanks for all the help guys. I'm done with the water pump and will try to refill tranny on the weekend.
qha000 is offline
    Transmission oil G-Benz230 R170 SLK-Class 8 12-18-2006 08:51 PM
    Transmission oil change with oil pump sam 100 W202 C-Class 8 12-14-2006 05:16 PM
    transmission oil ahottmale W201 190-Class 1 10-16-2006 10:12 AM
    1973 404 transmission drain/refill someotherguy Unimog 7 10-04-2005 01:45 PM
    Transmission Oil Ivin W163 M-Class 6 08-13-2003 08:25 AM
