» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W140 S-Class
Old 12-26-2006, 09:31 AM   #1 (permalink)
Vehicle: S320W
Door wont lock or unlock
The driver side door no more locks or unlocks. The key turns but I cannot feel the pump in action.
The passanger side and trunk work just fine.
Any ideas?
How much $?
Thanks!!
Very big car, with a very small engine.
///S320 is offline   Reply With Quote
Old 12-27-2006, 12:16 AM   #2 (permalink)
Date registered: Aug 2006
before you check the fuses and other click search in the right top bottom screen :P
unSobill320 is offline   Reply With Quote
Key ignition wont lock or unlock. OneLoveE55 W210 E50 AMG, E55 AMG 5 12-05-2006 10:25 AM
300SD door lock issue (can't lock with key, but can unlock) Mugsy90/10 W126 S,SE,SEC,SEL,SD,SDL Class 5 11-12-2006 07:12 PM
Door Lock & Unlock dixiebenz R171 SLK Class 13 03-27-2006 07:16 AM
Door Lock "Locked" in "Unlock" position PLS HLP!!! 300E Guru W124 E,CE,D,TD Class 2 07-25-2004 08:09 PM
Central lock (unlock) not working from drivers door Guest (MBNZ) W126 S,SE,SEC,SEL,SD,SDL Class 1 08-26-2002 09:15 PM
