How to reset check engine light?? - Mercedes-Benz Forum
post #1 of 13 (permalink) Old 10-30-2006, 04:28 PM Thread Starter
Date registered: Aug 2006
Can you guys tell me how to reset my check engine light on my 1994 S-320(w140) please ???
Benz S320 is offline
post #2 of 13 (permalink) Old 10-30-2006, 09:12 PM
bass1175's Avatar
Date registered: Feb 2005
Vehicle: 94 s420 98 s420
There should be an engine trouble code reader under your hood, you can delete the codes from there and that might take away your cel (check engine light).
Its going to be a 1 inch by 1 inch square box on the radiator side or passenger side, near where it says battery in trunk. Youll find this little box capped off, uncap it and you will see a push button with an led. you can do this with the engine running or with the ignition turned all the way right before you start the engine. Then go back to the box and push and hold the button for 4 seconds or so, and it will start flashing (if you have stored codes), write down the number of flashes, then you can press it again for 7 seconds to erase that one code. Press the button again for 4 seconds to read the next code, followed by 7 or so seconds to erase. Again writing the codes in between. I believe cars up to 95 have this on board code reader, my 94 has it, and received EGR and a few other codes in the past. These codes will only be engine codes, which what turns on the cel. Please tell us how it goes and anyone else that has a 95 or lower it wont hurt to check for any stored codes using this method.
bass1175 is offline
post #3 of 13 (permalink) Old 10-30-2006, 10:37 PM
bayhas's Avatar
Date registered: Oct 2005
Vehicle: SL55, 300SE, GL450, Daytona 955i
Quoted: 276 Post(s)
Send a message via MSN to bayhas Send a message via Yahoo to bayhas
Obd2
Garage:
Mercedes-Benz, W140 S Class S320 (AKA 300SE)
Mercedes-Benz, R230 SL Class SL55 (///AMG)
Mercedes-Benz, X164 GL CLass GL450
Triumph Daytona 955i
Former Mercs:
R129 SL Class SL500 (passed on) - W163 M Class ML430 Designo (for sale) - W140 S Class 500SEL(sold) - W140 S Class S320(sold) - W140 S Class S500(sold) - W140 S Class 500SEL(sold) - W201 190E 2.3(sold)
bayhas is online now
post #4 of 13 (permalink) Old 10-30-2006, 10:43 PM
bass1175's Avatar
whats obd2?
bass1175 is offline
post #5 of 13 (permalink) Old 10-30-2006, 10:47 PM
bass1175's Avatar
Anything below 95-96 shouldnt have an obd2 plug but a 38 pin Mercedes plug, no?
bass1175 is offline
post #6 of 13 (permalink) Old 10-30-2006, 11:12 PM
bass1175's Avatar
According to this page he should have the on board diagnostics reader and he also shouldnt have an obd2, if this dont work he would need to go to the dealer.
http://pages.prodigy.net/jforgione/MB_X11.html
bass1175 is offline
post #7 of 13 (permalink) Old 10-30-2006, 11:38 PM
bayhas's Avatar
Quoted: 276 Post(s)
OBD2 is all 96 and some 95, I didnt pay attention when i read the orifinal post and thought his car is 96.
94 has star 34 pin connector, the dealer should clear it for no cost.
Garage:
Former Mercs:
post #8 of 13 (permalink) Old 11-04-2006, 10:40 PM
Date registered: Jul 2004
check out this product....
http://autocheckengine.com/ or Ace5.0
anevin is offline
post #9 of 13 (permalink) Old 11-04-2006, 11:08 PM
bayhas's Avatar
Quoted: 276 Post(s)
this is for OBD II, aka 1996 models and up,
all pre 95 require a Mercedes STAR 38 pin scanner.
Garage:
Former Mercs:
post #10 of 13 (permalink) Old 06-30-2009, 07:13 AM
dbs600's Avatar
Date registered: Jul 2005
Vehicle: 1994 S500 Sedan
Quoted: 15 Post(s)
Why do you feel there wouldn't be a diagnostic charge (1 hour labor) for this? I ask because the check engine light on my '94 just came on, but drives fine. Instead of messing with OBD, if free, I'll just take it to the dealer...
dbs600 is offline
    Reset Check Engine light on 91 190E 2.3 ltooz W201 190-Class 0 04-18-2005 02:43 PM
    91 SL60 How do I reset the Check engine Light Bigpauly52 R129 SL-Class 7 01-01-2005 10:00 AM
    how do I reset the check engine light? shmelvin W140 S-Class 3 08-21-2004 01:51 PM
    Reset Check Engine Light Fresh94benz W124 E,CE,D,TD Class 1 05-31-2004 10:42 PM
    Reset Check Engine light badurski W202 C36 AMG, C43 AMG 0 09-06-2003 10:05 AM
