1997 S420 Timing Components - Mercedes-Benz Forum
post #1 of 5 (permalink) Old 10-27-2006, 11:45 AM Thread Starter
Date registered: Nov 2003
Vehicle: 1998 C280 Sport, 2009 GL 320
S430 Timing Components
My mechanic says that my timing chain and probably the related compenents (tensioners, idlers, etc.) may need to be replaced as well. He says that there is a special tool that is required to correctly set the timing. Does anyone know what this tool is? What is cost? Or p/n? Is there a substitute? An information would be appreciated.
kxmills is offline
post #2 of 5 (permalink) Old 10-27-2006, 12:24 PM
Date registered: Apr 2005
Vehicle: 92 500SEL
Send a message via AIM to a12play12 Send a message via Yahoo to a12play12
Alldata lists:
112 589 00 32 00 locating plate
112 589 01 32 00 locating plate
112 589 04 40 00 holding device
112 589 05 40 00 holding bushing
602 589 02 40 00 assembly links
You didnt list a year so i went off a 2000. Hope this helps.
Good Luck, Roger
a12play12 is offline
post #3 of 5 (permalink) Old 10-28-2006, 06:04 AM Thread Starter
Red face
I'm sorry it is 97 s420
kxmills is offline
post #4 of 5 (permalink) Old 10-28-2006, 07:22 AM
Vehicle: 92 500SEL
Well that changes things a little,
000 589 58 43 00
103 589 01 63 00
001 589 72 21 00
There is no description this time.
But by the picture the third number is a torque wrench.
Good Luck, Roger
post #5 of 5 (permalink) Old 10-31-2006, 07:51 AM Thread Starter
Where are the timing marks? I would like to remove the timing chain.
kxmills is offline
    Testing AC components Keith Lucy W126 S,SE,SEC,SEL,SD,SDL Class 4 05-08-2006 09:20 AM
    Timing Chain or Timing Belt on 230 Kompressor ? Bal C208/A208 CLK-Class 0 11-21-2005 01:08 PM
    BOSE Components? Benzonline W126 S,SE,SEC,SEL,SD,SDL Class 7 06-25-2004 02:48 PM
    Timing chain replacement/timing issue 1990 420SEL supersport6 W126 S,SE,SEC,SEL,SD,SDL Class 1 12-09-2003 02:03 PM
    Suspension components. Guest (MBNZ) W124 E,CE,D,TD Class 1 02-19-2001 08:09 PM
