Old 10-11-2006, 08:43 PM   #1 (permalink)
center brake light malfunction
hey guys, there seems to be something wrong with the center brake light on my car(the one inside the car, behind the rear seats). it keeps on going out and its not the bulb. The indicator light on the dash keeps on coming on so i check my brake lights and sure enough its the center one. I change the bulb and it works for a few minutes, then the dash light comes back on. so i check the bulb but its fine. i put it back in the socket and it works again for a few minutes. Im thinking its the contact beween the cap that holds the bulb and the socket because if the light goes out all i have to do it move it around alittle and it starts to work again but only for a minute or two. watcha guys think? is there somewhere online where i can purchase the whole center brake light socket assembly? thanks guys.
Marvin
1997 S320 Black
marv554 is offline   Reply With Quote
Old 10-12-2006, 02:59 AM   #2 (permalink)
Premium Member
bayhas's Avatar
Date registered: Oct 2005
Vehicle: 300SE 3.2L DOHC, 190E 2.3L SOHC, Saturn SCX 1.9L DOHC.
Premium Member
Send a message via MSN to bayhas Send a message via Yahoo to bayhas
Marvin
if you are getting the warning indicator while the light is TURNING ON that means you have used a light bulb with wrong wattage, get a halogen 20W bulb from the dealer.
if the bulb is going out completely, then yes, you need a new socket, and nothing to worry about, that is normal, in fact, mercedes recommends changing the bulb and the socket at the same time.
Mercedes-Benz, W140 S class 300SE
Mercedes-Benz, W201 190E 2.3 Stock
1996 Saturn SC1 + 95 DOHC head + 96 camcover + 98 Vsprings + 02 block + 00 crank + 91 header + 01 MP2 = SCX - Soon to be turbocharged.
bayhas is online now   Reply With Quote
Old 10-12-2006, 06:48 AM   #3 (permalink)
no i dont get the warning indicator when the light turns on, its only when the light goes out. so is there anywhere else to get this socket other than the dealer?? because the dealer is always overpriced. thanks
Old 10-12-2006, 10:19 AM   #4 (permalink)
Premium Member
bayhas's Avatar
Premium Member
true... however, that particular socket is only 6 bucks at the dealer.
Old 10-12-2006, 10:22 AM   #5 (permalink)
oh alright... thats not bad at all. Thanks alot bayhas, i appreciate it.
Marvin
Old 10-12-2006, 10:26 AM   #6 (permalink)
Premium Member
bayhas's Avatar
Premium Member
Marvin
you are very welcome...
Old 10-12-2006, 01:05 PM   #7 (permalink)
Date registered: Feb 2005
I will note I had all winter one year this issue with the light out indicator coming on when using the brake in order to shift into reverse, but only when it was cold enough outside. This issue was traced to a 7W bulb that had been installed in the third lamp, versus the proper 20W bulb. In cases where the bulb lamp comes on, check all the bulbs and ensure they are the proper wattage.
68882 is offline   Reply With Quote
Old 10-12-2006, 01:17 PM   #8 (permalink)
Date registered: Mar 2004
Vehicle: 1997 S600 sedan
I had the same problem. Turned out the socket contacts had become loose and intermittent with the bulb which actually caused arcing and degradation of the socket contacts, which then made the problem worse. I took the assembly out and cleaned up the contacts with sand paper and then bent the metal so that it made positive contact with the bulb. That was 2 years ago. No problems since.
Brett
Brett San Diego is online now   Reply With Quote
Old 10-13-2006, 07:45 PM   #9 (permalink)
I did what you said Brett and it worked like a charm. Thanks alot buddy!
Now i have another problem. Its more of a cosmetic problem thats been there for a while but i just havent payed much attention to it. Whats happened is that the plastic cover at the bottom of the B pillar has formed 2 long cracks on both sides. I have a picture that better illustrates what im taking about.
Now ive looked around online but so far i havent found any website that sells this part. I was wondering if anyone knows where i could possibly find this or if i would have to get it straight from the dealer. Thanks alot.
-Marvin
Old 10-14-2006, 01:31 PM   #10 (permalink)
Premium Member
bayhas's Avatar
Premium Member
dealer, its about 100 bucks or so...
Center Brake Light Bio W210 E-Class 8 02-23-2007 05:12 PM
Right headlamp/brake light intermittently malfunction notorious ALE W210 E-Class 0 06-16-2006 09:31 PM
center brake light help jcmorang Vintage Mercedes-Benz 2 12-07-2005 10:24 AM
Center brake light upgrade... E-Klasse W210 E-Class 15 03-14-2004 10:07 PM
Center brake light Guest (MBNZ) R129 SL Class 2 06-25-2002 11:57 AM
