The light bulb in my glove box is burnt out in my 96 S320 and I need to change it. Has anyone done this? I have tried gently prying from the sides and the rear with no luck and do not want to force it and break the plastic cover. Does anyone know where the holding clips are located( sides, rear) and where to pry the cover off or does the whole unit come off? Do you squeeze the lens by hand or use a tool to remove it to get to the bulb? Also does the on and off button on the light drop down when you remove the plastic lens? Any help will obviously be greatly appreciated.
