Just replaced the PSE pump. Dash locking and trunk working. Car won't start. Did a search , Brett you are the only 1 that commented about this. New battery I hear fuel pump aaarrgh! Keys not locking remotely
Do you mean the switch on the dash locks the car but the remotes do not?
Have you tried locking with the key, instead of the remote?
I have a situation on my car, where the drivers door lock vaccum element is worn. When I unlock the car, the driver's door will not unlock unless I use the key. Because of this, if I try to start the car with the driver's door not fully unlocked, the starter will not turn.
my drivers door also does not unluck without using key -- I have not noticed any realtion to starter. Door assist works fine -- I just thought this was normal?
Engines turns over then start error appears where the mileage is.Yes the button on the dash that says central locking system works. To make a long story short is there a way to reset the alarm system. Disconnecting and reconnecting the battery is not working.I've tried to sync the keys to no avail. I'm sure that it's the anti theft system causing the problem.
