Old 07-08-2006, 11:06 AM   #1 (permalink)
Date registered: Jul 2006
1994 350 s diesal
i have a 1994 350 s class turbo diesal.runs perfect. one problem. the car consumes oil at a alarming rate. it does not leak. it must be burning. any thoughts or ideas would be greatly appreciated.!
jjohn81602 is offline   Reply With Quote
Old 07-08-2006, 11:27 AM   #2 (permalink)
Date registered: Mar 2004
Vehicle: 1997 S600 sedan
First thought that comes to mind with burning oil in a turbo diesel is the turbo. I believe it's possible for seals/bearings to start to fail in the turbo and begin allowing oil into the intake. I really don't know much about the S350, though, and I would bow to a better opinion.
Also, consider posting on www.mercedesshop.com. It's a little more technical over there.
Brett
Brett San Diego is offline   Reply With Quote
Old 07-08-2006, 03:31 PM   #3 (permalink)
Premium Member
bayhas's Avatar
Date registered: Oct 2005
Vehicle: 300SE 3.2L DOHC, 190E 2.3L SOHC, Saturn SCX 1.9L DOHC.
Premium Member
Send a message via MSN to bayhas Send a message via Yahoo to bayhas
Brett
thats absolutely right, in fact its a common problem in any older turbocharged vehicle, fixing such a problem is not very expensive.
Mercedes-Benz, W140 S class 300SE
Mercedes-Benz, W201 190E 2.3 Stock
1996 Saturn SC1 + 95 DOHC head + 96 camcover + 98 Vsprings + 02 block + 00 crank + 91 header + 01 MP2 = SCX - Soon to be turbocharged.
bayhas is offline   Reply With Quote
Old 07-08-2006, 04:25 PM   #4 (permalink)
Date registered: Feb 2006
Ask around.. could be a pending major..
You could check with others, Jonathon would be a good start.
I believe I was told that the engine block from that period suffered from some specific engineering problems including the a severe issue with the process used to "harden" the cylinder walls, leading to a host of problems with mid-mileage engines.. a lot of engines from that period has serious issues that lead to MB engine replacement under warranty..which has since long elapsed..
I'd check out the story...
fabbrisd is offline   Reply With Quote
Old 07-10-2006, 01:02 AM   #5 (permalink)
S500L's Avatar
Date registered: Aug 2003
Vehicle: S 500 L
The story is more or less like this:
M.B. just basically enlarged the cylinder walls on the previous 3.0 liter to convert it to 3.5 liter, without any reinforcement to the block. This procedure severely weaked the cylinder walls which causes a catastrofic failure of the cylinder head (usually cylinder No.1, but sometimes others at the same time too).
Your oil consumption could be a sign of this catastrophic failure due to be happening soon.
Mercedes assumed the HUGE cost of fixing the engine on most cars since it happened on models which had less than 50,000 miles. I don't know if they still honor this warranty repair anymore.
I hope this is NOT your problem, buy I would have the engine checked ASAP.
A. R. R.
S 500 L, 1998
E 320 T, 1995
S500L is offline   Reply With Quote
Old 07-13-2006, 09:36 PM   #6 (permalink)
I am in the middle of this fix right now. The upper timing gear came apart - lost timing - pistons 2 and 5 hit the valves, prob bent rods but not sure - broke cam into 3 pieces. You can see the wear on the cylinder walls from the ovaling due to the screwed up bore/stroke ratio in this motor.
Failure is unrelated to turbo damage I found while taking it all apart. Big oil blow-by in the turbo. All the intake side was oil fouled. Rebuild of the turbo is 485.00 US - will be ready in a week.
Having the head re worked at Dover Cylinder head in Atlanta.
I'm using my 603.971 head with a 603.960 shortblock. Going back to the 3.0 liter before the bore and stroke disaster. I'm posting the pics of the engine work to a website - will give addy when more to see.
BCB Atlanta
1994S350 is offline   Reply With Quote
Old 07-13-2006, 09:48 PM   #7 (permalink)
BCB: Pics will be interesting to see. Would definitely like to get the website. Thanks for your comments on the turbo oil blow-by.
Brett
Old 06-28-2007, 08:45 PM   #8 (permalink)
Date registered: Mar 2006
Vehicle: 1994 S 350 Turbo Diesel
Id like to add that Benz has an upgrade for these rods. Seems they used the S300 rods on the S350 at first , that the number 1 conecting rod "bends" which creates blow by. My 603 motor ran but got worse with time. The last time I traveled before the rebuild, I got about 1 Qt. oil per 500 miles driving. Im hoping your fix is an easy one!
s350turbo is offline   Reply With Quote
