If you have ESP, you should have a little switch on the center console labeled "ESP". If not, you should have one labeled ASR. ASR was the stock traction control that sensed rear wheel spin only. ESP added steering wheel position and yaw sensing to the mix to further help rein in the car if you got it crosswise. I'm not sure on either account if the front wheel brakes are included in the control of the two computers.
BTW, on ASR equipped models, if you press the ASR button, the big yellow caution triangle in the middle of the cluster will illuminate letting you know that you have partially disabled the wheel braking function of the ASR computer. But alas, the car will still retard the engine timing to hobble the car if it senses wheel spin- so still no ability to smoke the tires.
1997 S500
2006 Chrysler Pacifica - nice but the engine and drivetrain suck
1995 Porsche 993- Yeah Baby!
pchansen1 - 2/12/2006 5:25 PM
AFAIK, it is the other way around, the wheel braking is
still enabled, but the motor trottle adjustment is
turned off. The same apply when you turn off ESP,
the wheel braking is still retained (ETS).
Even if the ESP is off, it is turned on again when
braking.
Yes, the ESP also monitor the front wheels.
A picture of the components in EPS is here;
http://mbwde.hl-users.com/Mediengalerie/Werksfotos/Technik/pages/B2000f5182.htm
BTW, the german s-klasse-club has posted a video
of EPS development under the member-only section.
As the club is recognized under MBCCCI, this is
the club to be in for the future.
http://www.s-klasse-club.de/
Vehicle: Two MB S Classes: 1989 560 SEL (W126) AND 1996 S500 (W140)
RE: Do I have ESP (Electronic Stability Program)?
sbou101 - 2/12/2006 2:54 PM
BUT, I can see the outline of a yellow triangle above the speedometer. Any Explanation?
i believe there is some form of traction control on your car, however, it is not in ASR or ESP. They had an earlier version that was a button with a tire on it. Is that what you have?
I don't have that either. I'll try to find the owner's manual and see what it has to say...
It has an ASR light on the dash which I have never seen come on. It also has the yellow triangle in the speedo, which also has never come on. I have the button on the centre console with the tire picture. Pressing it causes the red LED in the switch to light up. I have no owners manual.
Also, the yellow traingle and ASR light do not light up even when the engine is off and the ignition is on (all the other warning lights come on then).
Is this normal?
Any insight is appreciated.
Thanks, Ryan in South Africa
In Aller Welt
1976 W116 6.9 euro - Blau Silber over blue
1978 W116 6.9 euro - Rot over black
1980 W116 280SE euro - Silberblau over black
1980 R107 450SL euro - Rot over parchment
1992 W140 500SEL euro - Zirconsilber over black
1994 W202 C180 - Zirconsilber over grey
