Old 02-03-2006, 10:50 AM   #1 (permalink)
Date registered: Dec 2004
Vehicle: 1996 S600 Sebastian, 1999 SLK230 Kompressor
Can additional fog lights be installed?
Hey Guys, I think that an additional set of fog lamps on my Sebastian would look great. If one could place them in the far corners of the lower grill, similar to how they are on some other models, it would add another refinement/enhancment, not that these cars need it, to play with.
So, my questions: has anyone done or had this done? If so, then where are these lights available? How about dash switches that fit in with the original decor? How would you attach the lights and finally, is there a better way to create an opening for them w/o undermining the intergrity of the grill? Please lemme know. THANKS! [8D]
My Stable:
* 1996 S600 "Sebastian"
* 1999 SLK230 Kompressor "Darth's Tie Fighter Toy"
* 1996 C280 (sold)
* 2008 VW EOS Turbo Hard Top Convertible
* 2003 Denali
* 2003 Envoy
* 2000 Saab 93 Turbo
aristotled is offline   Reply With Quote
Old 02-03-2006, 05:48 PM   #2 (permalink)
1996_S500's Avatar
Date registered: Nov 2005
Vehicle: Two MB S Classes: 1989 560 SEL (W126) AND 1996 S500 (W140)
Send a message via ICQ to 1996_S500
RE: Can additional fog lights be installed?
nope. you will have to install a new body kit bimper for those fog lights. I wanted some as well, and i couldnt find any that would fit exaclty in those lower two pieces of the bumper. I am pretty sure that you will have to install a body kit.
Correct me if i am wrong.
My cars:
BLACK 1996 S500 (W140)
BURGUNDY 1989 560 SEL (W126)
____________________________________________
1996_S500 is offline   Reply With Quote
Old 02-03-2006, 09:28 PM   #3 (permalink)
Vehicle: 1993 300SEL/S320
1996_s500 - 2/3/2006 7:48 PM
Are you sure about that because there seems to be two panels that can be removed (I havn't tried)
See the two pannels in the lower of the front bumper, can those be removed?
NZ Benz is offline   Reply With Quote
Old 02-03-2006, 10:52 PM   #4 (permalink)
1996_S500's Avatar
NZ Benz - 2/3/2006 8:28 PM
yea. They can. i removed them before. They have wires underneath them that are connected, and they connect to something. Not quite sure what they connect to though.
Old 02-04-2006, 01:51 AM   #5 (permalink)
1996_s500 - 2/4/2006 12:52 AM
Is one of them a thick black wire with a metal tip, is that the outside tempreture gague? Because I found somthing like that hanging out the other day I tied it up and it must be near hte engine cause now my temp on the digital display is all out of whack. Does that effect anything else?
Old 02-04-2006, 02:38 AM   #6 (permalink)
Date registered: Jan 2005
Vehicle: w140 s300turbodiesel
that's the outside temperature sensor. it should be clamped to the inside of the small removable grill piece.
as far as fogs are concerned, I too have seen them but I'm not sure what the score with those is. I believe they were only there on pre-facelift models. mine are integrated.
posix is offline   Reply With Quote
Old 02-04-2006, 02:57 AM   #7 (permalink)
posix - 2/4/2006 4:38 AM
With the sensor where it is my temp usually sits at about 44c will that effect teh running of the car extra fans ac etc?
Old 02-04-2006, 10:16 AM   #8 (permalink)
1996_S500's Avatar
posix - 2/3/2006 1:38 AM
hmmm. There must be a company that makes them for post facelift w140s. I would be interested, if they are cheap.
Old 02-05-2006, 11:42 AM   #9 (permalink)
NZ Benz - 2/4/2006 10:57 AM
no that's just for the outside temperature display and (possibly but doubt it) aircon.
if your sensor is not seated properly spend some time to make sure it is - if you want your car to be spotless that is. there's a little clamp that you stick the sensor in and then screw the clamp to the inside of the grill piece. the sensor ends up being mounted lengthwise along one of the fins.
Old 02-05-2006, 01:06 PM   #10 (permalink)
posix - 2/5/2006 1:42 PM
Yea I've been 'getting round to it' for a while and I think I may have buggered my aircon by overworking it, oh well my fault anyway
