Old 01-23-2006, 03:38 PM   #1 (permalink)
Date registered: Jan 2006
Vehicle: 1994 S420
Crackling Sound Behind Dash
Hey Everyone,
Sometimes while I drive, a crackling sound can be heard from behind the ac control/dash area. It happens at least once every time I drive and it seems to happen when I turn off the ac (so I can open the windows), but it doesn't always do it when it is off. Any ideas? I'll try to get a recorded sound sample.
Thanks
sbou101 is offline   Reply With Quote
Old 01-23-2006, 03:55 PM   #2 (permalink)
Date registered: Aug 2005
Vehicle: 93 BENZ 400 SEL
Send a message via Yahoo to 93 BENZ S400SEL
RE: Crackling Sound Behind Dash
Try to use a better word to describe sound than crackling. Crackling like aluminun foil being crushed ?Snap, Crackle and POP was a cereal and I still dont know what it sounds like. Be more specific if you can.
93 BENZ S400SEL is offline   Reply With Quote
Old 01-23-2006, 06:52 PM   #3 (permalink)
Vehicle: 1994 S420
It sounds like sand falling onto aluminum foil. It sometimes also sounds like two pieces of plastic, that have been glued together, being separated.
Old 01-24-2006, 05:54 PM   #4 (permalink)
Vehicle: 90 300 SE ,85 300 GD
You may have some small leaves in your outside air intake. Check the outside intake with your hood in the upright position.
Ed Mclass is offline   Reply With Quote
Old 01-24-2006, 06:26 PM   #5 (permalink)
Vehicle: 1994 S420
I know that I cleaned out the top of the outside air intake. I'll try to see tomorrow if I can get inside it to clean it out. That is possible, right?
Old 01-25-2006, 02:57 PM   #6 (permalink)
Merc600sec's Avatar
Date registered: Mar 2004
Vehicle: SEC 600 COUPE (RHD) One of the chosen few.
Send a message via MSN to Merc600sec Send a message via Yahoo to Merc600sec
Right down inside.. look in my gallery for the pics..
If you've GOT to have a extension,
Have a BIG one.
Torque isn't cheap
Merc600sec is offline   Reply With Quote
Old 01-26-2006, 05:56 AM   #7 (permalink)
Vehicle: 99 S420
Send a message via MSN to DJ S420
I have a similar deal.I believe it's coming from 1 of the blower fans in the dash.
DJ S420 is offline   Reply With Quote
Old 02-12-2006, 07:09 AM   #8 (permalink)
Vehicle: 1994 S420
OK...
So, I've taken the car in for service, the first time I do this since I bought it 2 weeks ago used at 136 K miles. They're charging $100 just to check it out (the sound) and let's see if they discover something.
Old 09-13-2008, 06:47 AM   #9 (permalink)
Date registered: Dec 2006
Hey folks!
I just bought a 300SDL and I'm having the same problem -- at higher RPMs it sounds like a little elf is making popcorn somewhere behind the dash. While this is happening, I stop the car and I don't hear the sound coming from the engine compartment. Really sounds like it's somewhere behind the dash.
Thanks all! Aren't these wonderful cars?
mwoj is offline   Reply With Quote
Old 09-15-2008, 02:28 AM   #10 (permalink)
Premium Member
bayhas's Avatar
Date registered: Oct 2005
Vehicle: 300SE 3.2L DOHC, 190E 2.3L SOHC, Saturn SCX 1.9L DOHC.
Premium Member
Send a message via MSN to bayhas Send a message via Yahoo to bayhas
Originally Posted by mwoj View Post
Hey folks!
check your exhaust heat shield...
Mercedes-Benz, W140 S class 300SE
Mercedes-Benz, W201 190E 2.3 Stock
1996 Saturn SC1 + 95 DOHC head + 96 camcover + 98 Vsprings + 02 block + 00 crank + 91 header + 01 MP2 = SCX - Soon to be turbocharged.
bayhas is offline   Reply With Quote
