Old 01-13-2006, 12:09 PM   #1 (permalink)
Tbilisi79's Avatar
Date registered: Oct 2005
Vehicle: 500 SEL
Send a message via Yahoo to Tbilisi79
Engine mounts DONE
Let me tell you, wow!!! What a difference, I cannt believe I waited so long.
Motor is liquid smoot, shifts are amazing and no more nasty downshifts. If you suspect you engine mounts are dying, do yourself a favor. They are $100 of Wbay and another $100 of labor.
In my case, mechanic raptured my Tranny colling hose, it was old and I had to get a new one, nice precation anyhow, but annoying when it happened. Make sure yours is fine when you leave.
1992 500SEL. SOLD
1998 Lexus LS400
Tbilisi79 is offline   Reply With Quote
Old 01-13-2006, 12:23 PM   #2 (permalink)
Vehicle: 1993 300SEL/S320
RE: Engine mounts DONE
What are the symptoms of engine mounts that are going south?
NZ Benz is offline   Reply With Quote
Old 01-13-2006, 12:32 PM   #3 (permalink)
Tbilisi79's Avatar
Vehicle: 500 SEL
Goinf from Park to any other Gear you get a jerk, and when downshofting you feel a annoying jerk. Feeling vibrations through the steering wheel at idle and throughout the RPM range.
With new mounts, Motor is very very smoot, hardly noticable.
Old 01-13-2006, 12:38 PM   #4 (permalink)
I have a small jerk when moving from park to drive when the cars been on a hill but I think thats normal. I do get the odd vibration in the wheel but I think it may be corogations in our crappy roads. Car I check or have someone check for me easily just to make sure. Also just as general interest I find my car bumpy round town but smooth on the open road. It may have somthing to do with the low profile tyres but is that normal?
Old 01-13-2006, 10:41 PM   #5 (permalink)
Date registered: Mar 2004
Vehicle: 1997 S600 sedan
At 12 years old, if your motor mounts are original to the car...
they are old and should be replaced.
And BTW, the engine hasn't gotten any smoother, it just feels that way because the vibrations aren't getting transmitted to the frame of the car.
Brett
Brett San Diego is offline   Reply With Quote
Old 01-14-2006, 09:55 AM   #6 (permalink)
Date registered: Aug 2005
Vehicle: 93 BENZ 400 SEL
Send a message via Yahoo to 93 BENZ S400SEL
Brett your comment about motor mounts left me thinking.My car is a 93 with 65K miles on it and runs very smoothly.I experience no vibration at all. Do you think I should : A. have mechanic at least check on them or B.just go ahead and replace them or C. wait for some symptoms?
Thx
Peter
93 BENZ S400SEL is offline   Reply With Quote
Old 01-14-2006, 10:16 AM   #7 (permalink)
I should have said, they are likely old and probably should be replaced.
They should at least be inspected. Parts like this that are designed to be flexible and absorb vibrations (like suspension bushings) don't last forever. Engine mounts are one of those things that usually get ignored because even when they are bad, there usually isn't a catastrophic consequence. So people will just keep driving on old mounts not wanting to spend the extra money to maintain the car to perfection. They probably become used to the extra vibrations that may slowly develop from old mounts and not realize that it can be corrected.
I'm a bit of hypocrite. My car is 8 years old and has 116,000 miles, and I don't know whether the mounts have ever been replaced.
Brett
Old 01-14-2006, 07:34 PM   #8 (permalink)
Premium Member
bayhas's Avatar
Vehicle: 300SE 3.2L DOHC, 190E 2.3L SOHC, Saturn SCX 1.9L DOHC.
Premium Member
Send a message via MSN to bayhas Send a message via Yahoo to bayhas
does anyone have a pictorial "do it yourself" engine mount replacement tutorial?
Mercedes-Benz, W140 S class 300SE
Mercedes-Benz, W201 190E 2.3 Stock
1996 Saturn SC1 + 95 DOHC head + 96 camcover + 98 Vsprings + 02 block + 00 crank + 91 header + 01 MP2 = SCX - Soon to be turbocharged.
bayhas is offline   Reply With Quote
Old 01-14-2006, 08:07 PM   #9 (permalink)
I'll probably produce one in the next year.
If that's soon enough. [:)] But it'll be for the V12.
inetd did a brief write-up in a recent post. Short on pics but descriptive. But, I think it was also for the V12 (Maybe it was for the V8 since he has one of those, too.).
Brett
Old 01-14-2006, 08:21 PM   #10 (permalink)
Premium Member
bayhas's Avatar
Premium Member
it should be similar for all engines, not to mention, the mount itself looks very similar (if not the same) for all engines...
