Old 01-12-2006, 11:35 PM   #1 (permalink)
bass1175's Avatar
Date registered: Feb 2005
Vehicle: 94 s420
Changing the o2 sensor
Anyone changed this sensor if so please provide any tips, whether I would need to lift the car up or if I can get it from under the hood. Thanks
bass1175 is offline   Reply With Quote
Old 01-13-2006, 05:05 AM   #2 (permalink)
Merc600sec's Avatar
Date registered: Mar 2004
Vehicle: SEC 600 COUPE (RHD) One of the chosen few.
Send a message via MSN to Merc600sec Send a message via Yahoo to Merc600sec
RE: Changing the o2 sensor
Underside..lift the car , the O2 sensor is in the exhaust before the cat.And yes you can do it yourself.. not difficult remember to disconnect before you remove it do not use any sealing compound when fitting.. and only remove the cover on the sensor just prior to putting it in the hole..
If you've GOT to have a extension,
Have a BIG one.
Torque isn't cheap
Merc600sec is offline   Reply With Quote
Old 01-13-2006, 10:50 PM   #3 (permalink)
Vehicle: 1997 S600 sedan
If your car is OBDII compliant (1996 or newer in the US),
you will have a pre-cat and a post-cat O2 sensor on the exhaust for each bank of cylinders.
Easy to swap out using Rhino Ramps. The threads may be corroded and stuck in the exhaust pretty good. Disconnect electrical connector, put a 22 mm box-end wrench on the sensor. Use a cheater bar or hit the wrench with a hammer... whatever it takes to break it loose. Maybe a good soaking with penetrant will be helpful.
Brett
Brett San Diego is offline   Reply With Quote
Old 01-15-2006, 01:30 PM   #4 (permalink)
bass1175's Avatar
Vehicle: 94 s420
Thanks for the tip, I tried several times to go on ramps but they start rubbing on the bumber, They have newer plastic ones that I want to purchase that are less steep.
I found universal boosch sensor that comes with stripped colored wiring, to connect to the old harness. Theyre 120 bucks cheaper, would you guys trust these?
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&ru=http%3A%2F%2Fsearch.ebay .com%3A80%2Fsearch%2Fsearch.dll%3Fcgiurl%3Dhttp%25 3A%252F%252Fcgi.ebay.com%252Fws%252F%26fkr%3D1%26f rom%3DR8%26satitle%3D8028697126%26category0%3D%26f vi%3D1&item=8028697126
Old 04-05-2006, 07:23 PM   #5 (permalink)
Date registered: Oct 2005
RE: If your car is OBDII compliant (1996 or newer in the US),
Does that mean there are four O2 sensors for a V8 s500?
Are there two cats? I have not looked.
How do you know which one is Bank 1 Sensor 1
Thanks,
dm
dm567 is offline   Reply With Quote
Old 04-06-2006, 09:26 AM   #6 (permalink)
Date registered: Jul 2003
Vehicle: 92 400SE, 93 400E, 01 CLK320, 01 ML320, 98 Land Rover Discovery
On early model W140's V8s there is only 1 O2 sensor.
What model and year is your W140?
I would trust the Bosch universal O2 sensor, but I might not trust my ability to solder and seal the wiring to the old connector. If you try it, you might want to use the uncoated, barrel wire connectors with solder. Also use the heat shrink cable tubing to seal your connection.
Russell McMahon
2001 CLK320
2000 ML320
1992 400SE
1993 400E
rsmcmahon is offline   Reply With Quote
Old 04-06-2006, 09:41 AM   #7 (permalink)
Its a 2000 s500 and I have learned that there are two sensors, one before each cat.
Another benzworld member probably diagnosed my problem and I may not need to change the O2 sensor yet. Engine missfires and O2 sensor trouble codes may have been due to using regular instead of the required premium gasoline.
However, I'm glad you told me about the generic bosh O2 sensor. When the time comes I think I'll try it and save a bunch.
