Old 01-12-2006, 03:05 AM   #1 (permalink)
Date registered: Jan 2005
Vehicle: w140 s300turbodiesel
Rear blind
Anyone had problems with their electrical rear windscreen blind?
I had an intermittent fault about a month ago where it wouldn't retract. When I re-started the engine everything was fine since then untill 2 days ago. I could hear buzzing sound when pressing the button to go up or down but no movement.
I went to inspect the problem yesterday, pressed the button but no sounds were apparent this time. Checked fuse no. 35 (I think) under the hood but it's fine.
Does anyone have any ideas before I dig into the rear parcel shelf?
[xx(]
posix is offline   Reply With Quote
Old 01-16-2006, 03:41 PM   #2 (permalink)
RE: Rear blind
anyone?
Old 01-16-2006, 09:11 PM   #3 (permalink)
~BANNED~
Date registered: Jul 2004
Vehicle: 98 S500
RE: Rear blind
Well, alright. The retractable shade is one unit, supposedly otherwise unservicable. It can be done from the shelf in the trunk.
As far as mechanics of that thing go, I grease it with XPS2 (dry film) lube every now and then. When kids get in the car that's the FIRST thing the do - run it up and down so it gets plenty of stretchs.
Now sometimes the twin bars will hang up top if not lubed, and strip the little gears. The spring-wound netting seems to not like to retract after being exteneded for long periods.
Not sure if this answers your question. I think they're pretty expensive.
inetd is offline   Reply With Quote
Old 01-24-2006, 04:03 PM   #4 (permalink)
Hans Anders's Avatar
RE: Rear blind
Same here with da rear blind, unles lubricated da two bars hang up from time to time. I try and not extend fully when placing up to avoid dis problem.
Have only had to lubricate da gearbox once. All da best with your S=Klasse W140! hans
1994 Mercedes W-140 A Lifestyle of Dutchland Excellence.... S-Klasse
Hans Anders is offline   Reply With Quote
