Old 01-11-2006, 12:19 PM   #1 (permalink)
Date registered: Jan 2006
fuel consumption gauge help please
I have a problem with my 1993 s320, the fuel consumption gauge will shoot across to the right side of the scale as soon as the engine is started, with just the ignition on all appears normal . I have done the self diagnostic test reading 24/16 and all other gauges( except the clock does not work) are accurate. I have done an instrument cluster voltage supply test and all have voltage.
As a side note: the guage connections appear the same as a 96/97 but the front is the early digital temp display only.
Any advice gratefully recieved!
crane is offline   Reply With Quote
Old 01-11-2006, 12:25 PM   #2 (permalink)
Tbilisi79's Avatar
Date registered: Oct 2005
Vehicle: 500 SEL
Send a message via Yahoo to Tbilisi79
RE: fuel consumption gauge help please
I think this is normal. Mine is in 30s when idling and the goes to the right as i drive.
1992 500SEL. SOLD
1998 Lexus LS400
Tbilisi79 is offline   Reply With Quote
Old 01-11-2006, 12:53 PM   #3 (permalink)
If I am reading correctly yours must sit on the left side and move to the right when you are moving. Mine starts on the right and stays there, the meter only goes to 20?? surely that cant be correct?
Old 01-11-2006, 01:25 PM   #4 (permalink)
Nimrodthewombat's Avatar
Date registered: Dec 2002
Vehicle: 500 SEL (W140- the King of the Road!) SL500 (My new baby!)
mine sits on the left when idling then goes to the right when I start off. The dealer said it was normal (it does contradict what is says in the owners manual), but the dealer said it had something to do with replacing the instrument cluster with an update when it fried itself about 5 years ago.
1993 500 SEL (W140-the King of the road!)
1992 500SL (My New Baby!)
You know you're German if:
You went to school in a Gymnasium
You check your shoes for candy on December 6
You have real candles on your Christmas tree
You know a Frankfurter is a person not a hotdog
Schnitzel with noodles is your favorite meal, not a song in a cheesy musical!
You drive the Autobahn in a Mercedes-Benz at the speed of sound!
Nimrodthewombat is offline   Reply With Quote
Old 01-11-2006, 01:41 PM   #5 (permalink)
Tbilisi79's Avatar
Vehicle: 500 SEL
Exactly, manual says it should be at the right side at idle, so dont worry.
That stupid gauge shouldt even be there, or the dial should be 0-10, since the car doesnt get more than 10 mog anyway. hehe[:D]
ahhh..3 more hours till I get out f work and drive again.
Old 01-11-2006, 11:25 PM   #6 (permalink)
Vehicle: 1993 300SEL/S320
The fuel consumption indicator (if all are the same as mine) reads L or I guess in your case Gl to 100km or miles. The point then being that if you are sitting still with the engine running your fuel consumption will be higher per 100km/60m. This seems to be normal to me.
NZ Benz is offline   Reply With Quote
Old 01-12-2006, 04:06 PM   #7 (permalink)
The gauges sometimes get stuck. If you remove the cluster unit and rotate it a few times, it may help. I had a gauge with a similar problem. Electrical contact spray on the contact may also help...Do not us WD40...get some from contact cleaner from Radio Shack. It's frustrating that it does not work, but when they do work they are not accurate!
chrisw140 is offline   Reply With Quote
Old 01-12-2006, 07:43 PM   #8 (permalink)
ychachad's Avatar
Vehicle: 1995 S420
Mine hovers close to 30 mpg at 65 mph using 93 octane, with the mods I have done. New chip, 2xK&N filters, 8x Bosch Patinum+4, and tyre pressure of 32F, 36R. In reality I get 28mpg all the time on the highway.
1995 MB S420
1995 Lexus LS400
1992 Lexus LS400
1989 Honda NX250
ychachad is offline   Reply With Quote
Old 01-12-2006, 09:49 PM   #9 (permalink)
ychachad - 1/12/2006 9:43 PM
What are your octane ratings like over there? I was told the other day that they were low. For example in New Zealand we have two fuels a 91 and a 97.
Old 01-13-2006, 08:40 AM   #10 (permalink)
ychachad's Avatar
Vehicle: 1995 S420
In most places in the US, octane rating is 87, 89 and either 91 or 93 for premium.
