When I indicate to turn right all the warning lamps momentarily light up on the instrument cluster and then go out again, with the seatblet warning lamp sometimes staying on for a few seconds before going out. Is this a problem with the turn signal switch or is there a fault in the cluster itself ? Is there a repair for this or does it mean a new cluster ($xxx !)
