Old 11-26-2005, 10:06 AM   #1 (permalink)
Date registered: Jul 2005
any idea?
Does anyone have an idea why my heater stoped blowing hot air? it blows cold air when ever i turn the heater on?
what could be the issue?
3xnet is offline   Reply With Quote
Old 11-26-2005, 11:56 AM   #2 (permalink)
Date registered: Mar 2004
Vehicle: 1997 S600 sedan
Duovalve problem, maybe.
The duovalve regulates the amount of hot coolant that flows through the heater core. If your valve has failed and no longer operates, no hot coolant will ever circulate to the heater core.
See pcmaher's excellent work rebuilding his rear climate control valve to see what the beast looks like in general.
http://v12uberalles.com/Rear_AC_System.htm
The main climate control duovalve is similar. It's mounted just behind the driver's side headlamp in US cars.
Brett
Brett San Diego is offline   Reply With Quote
Old 11-26-2005, 06:48 PM   #3 (permalink)
RE: Duovalve problem, maybe.
Brett, thank you for caring to reply. I really appreciate it. they told me today that i need heat control unit. it is located just behind driver side head lamp. i guess its the same thing you refered to on your post.
thanks
Old 11-26-2005, 08:43 PM   #4 (permalink)
ulflei's Avatar
Date registered: Aug 2005
Vehicle: S 420 300SL
RE: any idea?
I think a heat controll unit is not the same as a duo valve,at least it sounds more expensive.
ulflei is offline   Reply With Quote
Old 11-26-2005, 10:43 PM   #5 (permalink)
I don't know what your mechanic is charging for the valve, but
here it is from an aftermarket supplier. It could be cheaper from another source.
http://www.autohausaz.com/search/productx.aspx?sid=4blkip45nortuoz0xkdvn2q4&makeid= 800016@MERCEDES&modelid=1195848@S600%20140.0XX&yea r=1997&cid=24@AC%20%26%20Heat%20-%20Climate%20Control&gid=6860@AC%20%26%20Heater%20 Control%20Valve
Looks like a piece of cake to swap it out. You might also try the climate control diagnostics as outlined in the "knowledge base" thread. If the duovalve has an open circuit, it should be indicated.
Brett
