Old 11-01-2005, 04:06 PM   #1 (permalink)
Date registered: Oct 2004
Vehicle: 99 SL500 92 300SE
92 300SE Parking brake adjustment
I need to tighten cable for parking brake for my 92 300se due to Brake warning light comes on and stay on.
Anyone know 'How to do it ?'
Thank you,
land747 is offline   Reply With Quote
Old 11-01-2005, 06:46 PM   #2 (permalink)
Date registered: Aug 2005
Vehicle: 93 BENZ 400 SEL
Send a message via Yahoo to 93 BENZ S400SEL
RE: 92 300SE Parking brake adjustment
The brake warning light probably has nothing to do with your parking brake. What makes you think thats what the light is for?
Correct me someone who knows more, if I am wrong
PGP
93 BENZ S400SEL is offline   Reply With Quote
Old 11-01-2005, 08:04 PM   #3 (permalink)
When parking brake pedal goes down to certain point, brake warning light comes on. If i lift parking brake pedal slightly move upward, brake warning light goes off.
My parking brake pedal does not return to completely up position because return spring of pedal is warn out, I believe.
So it may not be cable adjustment, just simply pedal return spring.
Old 11-04-2005, 01:44 PM   #4 (permalink)
Merc600sec's Avatar
Date registered: Mar 2004
Vehicle: SEC 600 COUPE (RHD) One of the chosen few.
Send a message via MSN to Merc600sec Send a message via Yahoo to Merc600sec
The adjuster is on the underside above the exhaust.. just before the rear subframe..
I have a pic somewher.. will try to find it for you...
If you've GOT to have a extension,
Have a BIG one.
Torque isn't cheap
Merc600sec is offline   Reply With Quote
