Old 10-09-2005, 07:39 PM   #1 (permalink)
Date registered: Jan 2005
Vehicle: 1994 S350D
Euro head lights
OK purchased e code head lights and to my horror i realized that the connector on the harness was different does anybody know were i can purchase the euro piece with the six holes see pic ( PLEASE HELP NO HEADLIGHTS UNTIL I GET THE SET OF COONECTORS) to think to be stopped by 2 silly connectors
I part would also help
harleyman07105 is offline   Reply With Quote
Old 10-09-2005, 09:20 PM   #2 (permalink)
Date registered: Mar 2004
Vehicle: 1997 S600 sedan
Might be easier to buy the euro car to fit the headlights. :)
What about the seller of the headlights? Does that organization not support its products?
Brett
Brett San Diego is offline   Reply With Quote
Old 10-12-2005, 09:05 AM   #3 (permalink)
W140Gill's Avatar
Date registered: Jan 2003
Vehicle: W140 S class, E31 850Ci, E83 X3 3.0i Sport
RE: Euro head lights
harleyman07105 - 10/8/2005 2:39 AM
Supply the correct part number and I will see what I can do.
W140Gill is offline   Reply With Quote
Old 10-12-2005, 06:25 PM   #4 (permalink)
Vehicle: 1994 S350D
ok found it if anybody is ever in the same situation here is the part # A 126 545 01 28
Old 10-13-2005, 01:06 AM   #5 (permalink)
bass1175's Avatar
Date registered: Feb 2005
Vehicle: 94 s420
Do you actually have 6 pins sticking out of the headlight plug? I was just messing with mine, and I noticed the plug ( on the headlight side) has 6 slots, but 2 are totally blank. so only 4 pins are sticking out. Do you actually have the full 6 pins? If so where will those two wires come from? Maybe the euro connector bridges two pins internally?
If you only have the 4 pins then its just a connector/fittment issue not electrical. You can plug each wire wire directly bypassing the connector but you would need a diagram of what wire goes where or look at your old headlight and plug. Hopefully youll find the right adaptor.
bass1175 is offline   Reply With Quote
