Old 08-31-2005, 12:53 PM   #1 (permalink)
pcmaher's Avatar
Date registered: Jun 2004
Vehicle: 1995 S600 (sold)
Electrical Problem, Combination Relay or something else?
It never ends....
Driving to work this morning, start merging into left turn lane. Hit turn signal, doesn’t come on. Battery and ADS light both come on. Radio goes off. Car keeps running, no signs of hesitation or stalling. Pull into lot, leave engine running. Speedo stuck at 38 mph, and Tach stuck at 1,250. Shut engine off, heard regular clicking (relay?) from trunk. Was able to pop trunk, but by the time I got to the trunk I could not hear the clicking anymore. Went back inside the car. Tried turning ignition on again, noticed that caution lights did not all illuminate as usual. Some did, others didn’t. ADS light stays on.
Went back out after researching on Forum.
Opened door, no interior lights. Speedo and Tach still stuck. Clock stopped. Hazard lights don’t work. Trunk release works. Fuel gage zero. Started car, no problem. Battery light on, Fuel gage still zero and Low Fuel level light on. Oil level light on, oil pressure gage zero. ADS and Seatbelt lights on.
Pressing Hazard switch turns off all the caution lights except ADS light, and does not turn Hazard lights on. As soon as Hazard switch is released, caution lights come back on. Turn signals still not working. Climate Control works. Radio working, but stays on without key. Door close assist works. Rear window heater does not stay on. Light in rocker switch comes on, but won’t stay toggled on. Rear shade works.
I need to check fuses, battery voltage, Combination relay, and pull codes tonight.
Any thoughts on this my friends?
1995 S600, 1 of 618 (sold)
"Speed is just a question of money...how fast you wanna go?"
LONG LIVE THE W140!
Visit my Web Page at http://v12uberalles.com
pcmaher is offline   Reply With Quote
Old 08-31-2005, 01:33 PM   #2 (permalink)
Date registered: Mar 2004
Vehicle: 1997 S600 sedan
Ignition switch going bad?
Brett San Diego is offline   Reply With Quote
Old 08-31-2005, 09:39 PM   #3 (permalink)
pcmaher's Avatar
RE: Ignition switch going bad?
Good thought Brett. I don't know. Will look at schematics.
Wires under the hood look good. As some of you know, I rewired the AMM's and passenger ETA. Balance of wires look newer or in good shape.
I've had the dash apart a few times in the past, including pulling the instrument cluster out. All wires looked good. Nothing like those near hot stuff under the hood.
Battery was replaced 7/28/05. Voltage measured 12.75 with car off, right after short run. I will check alternator output voltage to see what alternator is doing.
Started the car repeatedly with no problem.
No codes other than those left over from my rear duovalve rebuild. Cleared those, they're gone now.
I'm suspecting the Combination Relay (N10, N10/2). This item controls wipers, hazards, turn signals, instrument cluster indicator lights, and rear window heater. I pulled it out of the fuse box, and examined the myriad of wires down inside the box. They also look very good. Can't see a way to get the N10 open to see what the insides are about. Also can't find a test procedure to see if it's working right. Whatever is going on, it's intermittent. Instrument cluster is back to life, along with turn signals and hazards.
Anybody know how to test the Combination Relay?
Old 08-31-2005, 10:32 PM   #4 (permalink)
Ignition switches have been a problem with earlier model
Porsche Boxsters, and the symptoms are bizarre seemingly unrelated electrical gremlins. A new switch fixes everything in the Boxster, so this was the first thing that came to my mind.
Brett
Old 09-01-2005, 12:31 AM   #5 (permalink)
mercS600's Avatar
Date registered: Nov 2003
Vehicle: S600L
RE: Electrical Problem, Combination Relay or something else?
Have had this problem with both my S classes (S320 & 600SEL),in my case it was the combination relay in the engine compartment - cost @ÂŁ55 UK .Strange how the hazard switch has that effect on the symptoms isn't it![:0][:)]
mercS600 is offline   Reply With Quote
Old 09-01-2005, 06:20 AM   #6 (permalink)
pcmaher's Avatar
merc600, was it also an intermittent problem in your cases?
Old 09-01-2005, 09:57 AM   #7 (permalink)
mercS600's Avatar
Vehicle: S600L
Yes,it drove me mad as well[xx(]but a quick trip to the main stealers sorted it![:D]I thought of all worse case senarios!
Old 09-02-2005, 11:44 PM   #8 (permalink)
c140v8's Avatar
Date registered: Apr 2005
Vehicle: 1995 S500 Coupe (SOLD), 1986 420SEL
maybe this could be my problem also
(hazard lights turn on and wont go off, windscreen wipers go when you turn on the hazaed lights, intermitant wont go etc)
i'll look into it
c140v8 is offline   Reply With Quote
