Old 08-30-2005, 09:56 PM   #1 (permalink)
Date registered: Jul 2003
Vehicle: 92 400SE, 93 400E, 01 CLK320, 01 ML320, 98 Land Rover Discovery
My water pump on my 92 400se has begun to leak from the “seep hole.� Since this my 1st attempt at replacing a water pump on a M119 engine, I was hoping others in the forum might have tips before I begin my venture.
I did a forum search and can't find information on water pump on a M119.
Below is the procedure outlined on the Alldata.com website for my model of car.
I have decided not to use any sealants on the “paper gasket� that accompany the water pump.
I looked into the engine bay tonight and the water pump looks fairly easy to access on the W140 body. But after reviewing the “Preparation� steps below .. Geeze.. do I need to remove the -Viscous fan clutch carrier removed and Harmonic balancer and drive belt removed. Before removing the water pump?
I sure hope not!
AllData Procedure
Preparation
• Viscous fan clutch carrier removed. See: Fan Clutch\Service and Repair
• Harmonic balancer and drive belt removed. See: Engine
Removal and Installation
• Detach coolant hoses (4), (5) and (6), attach.
• Unbolt connection cover at top (2) with engine lifting eye (1), bolt on Tighten to: 21 Nm.
• Replace gasket (2a).
• Model 210 With Secondary Air Injection: unbolt retaining plate with switchover valve for secondary air injection at coolant pump (3), bolt on.
• Unbolt coolant pump (3).
• Clean sealing surfaces.
• Replace gasket (3a).
• Install coolant pump (3) on, bolt on. Tighten to: 21 Nm.
Pay attention to different bolt lengths, see bolt diagram illustration above.
• Check cooling system for leaks. See: Testing and Inspection
• Tighten the bolts of cover at top to coolant pump to: 21 Nm
Russell McMahon
2001 CLK320
2000 ML320
1992 400SE
1993 400E
rsmcmahon is offline   Reply With Quote
