for some reason my light switch doesnt light up...and also my high beams dont flicker....if you push the stick for the high beams away from you, the high beams stay on, but when you push it towards you, it should flicker the high beams... just wondering if anyone knew of a problem like this and how i could fix it... thanks for any feedback
Sounds like the bulb is out. My flasher function doesn't work either. I can turn hi beams on, but flasher doesn't work. It worked for a little while after I took it apart, but then crapped out again. The contacts are worn. I haven't bothered replacing it. US drivers don't know what flashing hi beams means anyway...
1995 S600, 1 of 618 (sold)
"Speed is just a question of money...how fast you wanna go?"
Air grate (1)
push out with plastic wedge.
Screws (2 and 3)
screw out, hold cover down for access.
Screw (4)
screw out.
Screws (5, 6 and 7)
screw out (8 mm ).
Nut (8)
screw off (10 mm ).
Cover (9)
pull down and remove.
Reinstall
in opposite order.
See second diagram.
Quiescent current retention unit
disconnect, connect.
Ground cable at battery
Steering column adjustment control button (1)
pull off, push on.
Locking element of exterior lamp switch (2)
press in with a screwdriver and pull off exterior lamp switch (2), press on.
Bulb (3)
pull out, insert.
Screws (4)
unscrew, screw in.
Covers (5 and 6)
take out, insert.
Screw (7)
unscrew, screw in.
NOTE: Hold adjusting lever (8) with plate nut (9) for the screw (7) to prevent it turning when installing cover below instrument panel.
Nut (10)
unscrew, screw on.
Cover (11)
take off, fit on.
Pneumatic line (12) except with HPF and xenon headlamps
pull off, fit on.
Lighting (13)
withdraw, push in.
Exterior lamp switch (S1)
turn to left and take out downward; insert from below and turn to right.
NOTE: Ensure the retaining lugs (arrow) on the exterior lamp switch (S1) are correctly seated.
The combination switch is a tricky one. It involves removing the air bag. MUST USE EXTREME CAUTION! Instructions are lengthy. I'll send you private e-mail.
OK.
in my car, the positions in the area above the actaula switch are lit. But, the knob, itself showing the arrow is NOT lit. The centre orange light in the knob only lights up when I turn on the rear fog lamp. IS that correct that the knob itself has no lights other than the rear fog lamp?
