Old 08-29-2005, 01:48 PM   #1 (permalink)
Desert_Fox's Avatar
Date registered: May 2005
Vehicle: 1997 S500
Is my mirror repairable?
[:(]My passenger side mirror is kinda broken guys. I was having the car washed when the guy wiping the car down pushed on it an it went to a halfway "open position." I used the motor to try and reset but it won't come to rest in it's proper spot. There is a small gap where you can still see the innards. I thought to myself that it shouldn't have come apart with such little pressure.
Sure enough, when I checked the previous owners service records he had the mirror repaired by the dealer. The invoice even had a comment that the dealer suggested replacement and the customer insisted that it be repaired. Obviously not a very good job.
So my question is, can this be repaired? How much should it cost? Is there something I can do to fix it myself? I really not in the mood to by a replacement for $450. THANKS!
Desert_Fox is offline   Reply With Quote
Old 08-29-2005, 11:59 PM   #2 (permalink)
W208Cab's Avatar
Date registered: Aug 2005
Vehicle: CLK320 Con, S320L
Send a message via AIM to W208Cab
RE: Is my mirror repairable?
If you search the forum for W140 mirrors, it would turn up something that I have read.
We all have folding and unfolding problem more or less on this model as well as myself. Some guys suggest using WD40 or some other grease.
I just bought a pair from Germany and they were cheaper than U.S. stealer price. It's being shipped to me now.
Good luck.
My short History with MB:
CLK320 Cabriolet 2001
S320L (V) 1997
S320 SWB 1997 (Sold)
E320 1995 (Sold)
W208Cab is offline   Reply With Quote
Old 08-30-2005, 01:05 AM   #3 (permalink)
barry putnam's Avatar
Date registered: May 2003
Vehicle: 1995 MB S320V: 2006 kawasaki vulcan 900 lt
Bad Desert_fax Bad, you must wash a 140 yourself if you want it done propertly. You may let your Butler do it but you must whip him if its not right.
Woo hoo ,,where can you get a mirror for only $450.??The insurance Co. paid $1100, when mine was damaged by the lower hooligan classes.
Barry
BECAUSE SIZE REALY DOES MATTER, W140
barry putnam is offline   Reply With Quote
Old 08-30-2005, 11:39 AM   #4 (permalink)
W208Cab's Avatar
I got both left and right from germany including shipping and handling with UPS air for 600 Euro.
Old 09-20-2005, 05:49 PM   #5 (permalink)
Date registered: Sep 2003
Vehicle: 230E/230TE/S320/260E/320d
I might be able to get cheap S class parts from a breaker I know, let me know if you need a mirror or any item in fact.
cheers
S320 (W140)-97
230E (W123)-82
230TE (W123)-84
260E (W124)-89
w140benz is offline   Reply With Quote
Old 09-29-2005, 11:56 AM   #6 (permalink)
Date registered: Jan 2005
Vehicle: w140 s300turbodiesel
If one of your mirrors isn't opening as much as it should - i.e. it's only half-way open - then try closing them both fully and then opening them again by using the inside electric mirror button thingy. If not the first time then do it 2 or 3 times. Close fully (untill the buzzing stops) then open fully (again, untill the buzzing stops) and then close and open again and see if it's ok. It should be.
posix is offline   Reply With Quote
