Old 08-23-2005, 10:59 PM   #1 (permalink)
bass1175's Avatar
Date registered: Feb 2005
Vehicle: 94 s420
1993 300 se loses total reverse.
My uncle just lost reverse in his s class , his forward gears are all strong. My question is, can he fix this reverse problem with the tranny in place or must it be removed. If he removes it he plans on doing a complete overhaul, which his mechanic quoted him 2200. He had a delay in reverse for a while now. I hope i dont have to deal with this problem since i have a 3 second delay in reverse as well.
bass1175 is offline   Reply With Quote
Old 08-24-2005, 12:47 AM   #2 (permalink)
Date registered: Mar 2004
Vehicle: 1997 S600 sedan
There was a nice post I believe by BENZDOC not too long ago
describing what is happening when reverse takes several seconds to engage. Essentially, it is a valve in the valve body going bad as I recall. Eventually it degrades to the point where reverse won't engage at all. Yours is headed in that direction. Look up his post.
I don't know about pulling the entire transmission to repair. Seems like you may have to. I think you may as well overhaul the whole thing if your're going to keep the car a while.
Brett
Brett San Diego is offline   Reply With Quote
Old 08-24-2005, 09:16 AM   #3 (permalink)
Date registered: May 2004
RE: 1993 300 se loses total reverse.
My '92 300SE did the exact same thing. I talked to what seemed like a million people about this and they all said it needed to be rebuilt. And to be honest with you $2200 is on the low side of the quotes I received. I know that this is not what you wanted to hear, but at least you will have a new transmission when it is all done and said. Just out of curiosity, how many miles does your car have?
mpayne is offline   Reply With Quote
Old 08-24-2005, 09:43 AM   #4 (permalink)
bass1175's Avatar
Vehicle: 94 s420
The 300 se has approx 120k miles on it, and he babies it. My car (94 s420) which had a delay in reverse for four years, has 140k miles on it.
Old 08-24-2005, 11:19 AM   #5 (permalink)
That is almost exactly the mileage (125,000) that my 300SE reverse went out. I also have a '93 300SE with 117,000 and the transmission is working great. Knock on wood!!!!!!!!!!!
Old 08-24-2005, 09:14 PM   #6 (permalink)
Date registered: Oct 2003
Vehicle: 00 S500,99 4wgn,87TD
http://benzworld.org/forums/forums/thread-view.asp?tid=1181818&posts=8
BENZDOC is offline   Reply With Quote
Old 08-24-2005, 09:24 PM   #7 (permalink)
bass1175's Avatar
Vehicle: 94 s420
thanks benzdoc
Old 08-31-2005, 03:02 PM   #8 (permalink)
bass1175's Avatar
Vehicle: 94 s420
Just to add to this, I was just speaking with my uncle, he said this problem happened one day after changing his trans fluid. He used dextron 3, a benz filter and they didnt do a torque converter flush. I always heard of not changing your fluid if your tranny is on its way. I was wondering if this is the right fluid and I will double check the level. Now
I am scared to flush mine, incase I totaly lose reverse as well.
Old 09-01-2005, 03:14 AM   #9 (permalink)
Date registered: Jul 2005
Vehicle: 1996 Mercedes-Benz S 600 L, 2001 Mercedes-Benz E 220 CDI, 1984 Mercedes-Benz 300GD, 1995 BMW328i Cab
bass1175 - 8/31/2005 11:02 AM
Nah, i guess his reverse gear have been a bit slow getting in lately, then when he changed the fluid he might have been a bit sloppy with the cleanness, and got some dirt in the oil pan. But changing the oil without changing in the converter is like peeing in the ocean it helps nothing.
I guess that his reverse gear is a bit worn out, and might need a renewal, or maybe just to get the pressure back again…
Simen Malerbakken
'96 Mercedes-Benz S 600 L
'01 Mercedes-Benz E 220 CDI
'84 Mercedes-Benz 300 GD turbo
'95 BMW 328i Cab
Simen is offline   Reply With Quote
Old 09-01-2005, 04:14 AM   #10 (permalink)
bass1175's Avatar
Vehicle: 94 s420
What would control pressure for reverse? Thanks
