Old 08-18-2005, 08:03 PM   #1 (permalink)
Date registered: Jul 2005
Need help w/ fuel pressure regulator change
Has anyone out there ever changed the fuel pressure regulator?
I need to know where it is located and if any special tools are needed to change it on my S500. Thanks for any insight you can give me.
Mn MBenz is offline   Reply With Quote
Old 08-19-2005, 11:04 AM   #2 (permalink)
Date registered: Jul 2003
Vehicle: 92 400SE, 93 400E, 01 CLK320, 01 ML320, 98 Land Rover Discovery
RE: Need help w/ fuel pressure regulator change
I have attached a picture of the fuel pressure regulator and the location.
You'll need "snap ring" pliers to remove the regulator.
BIG caution!!!! Do not perform this task with the engine HOT!!!!
I placed a towel around the regulator area, to soak up gas the will seep out when you remove the regulator.
The recommended procedure states you should relieve the fuel pressure at the fuel pressure line before removing the regulator.
Russell McMahon
2001 CLK320
2000 ML320
1992 400SE
1993 400E
rsmcmahon is offline   Reply With Quote
Old 08-25-2005, 05:30 AM   #3 (permalink)
Thanks!
