Rear Windows . . . a large cracking sound and now they won't go up . . . - Mercedes-Benz Forum
post #1 of 14 (permalink) Old 07-31-2005, 12:55 PM Thread Starter
bdonkersgoed's Avatar
Date registered: Sep 2003
Vehicle: 93 300SE, 07 BMW 328i Coupe, 01 GSX-R1000
Hey Guys,
My Dad is having a problem with the rear right-hand-side window in his '93 300SE. I was rolling down the window the other day when I heard a pretty loud "crack" sound. I tried to roll the window back up, but it wouldn't budge, so I used my hands to push it up manually. Even using my hands, I can't get it to go all of the way up. There is still about a half-inch opening at the top of the window.
I know that there are problems with the rear window regulators in this car, but I don't think that is my problem due to the loud cracking sound, and due to the fact that I can't even push the window up all the way.
Any suggestions? Do you think that the window came off of it's track? If so, is it a real PIA to get the door skin off to fix the problem?
Thanks for the help!
Bryan
bdonkersgoed is offline
post #2 of 14 (permalink) Old 07-31-2005, 03:04 PM
W140Gill's Avatar
Date registered: Jan 2003
Vehicle: W140 S class, E31 850Ci, XC90 Exec AWD geartronic
RE: Rear Windows . . . a large cracking sound and now they won't go up . . .
Hi bdonkersgoed.
Its not tracks. I am afraid its the dreaded regulator.The steel cable has chewed up the nylon gearing. Thats what you heard crack.
Time to get that regulator changed [:0]
To roll up the window temporarily before the perminant fix, you must tap window button down for a split second and then press upward while a buddy gives it a helping hand by pulling the glass up by hand. Keep doing this in stages until you get it all the way up.
W140Gill is offline
post #3 of 14 (permalink) Old 07-31-2005, 03:40 PM
Date registered: Dec 2002
Vehicle: 92 500SEL to 01 E320T and others
YUP
One hour plus regulator, MB changed my battery tried to sync window, it stayed down...pulled it up put in a wedge, off to the shop!
Peter Guenther is offline
post #4 of 14 (permalink) Old 07-31-2005, 07:54 PM Thread Starter
Crappy! I thought it would just be a simple fix that I could do on my own without any parts needed. I am in final exams right now so I don't even have time for two weeks to really look at it :( I always thought that the regulator was an electrical part; I guess I was wrong.
How much did you guys have to pay for the part? Is it something that you can change yourself, or should I get the dealer to do it?
Thanks,
Bryan
post #5 of 14 (permalink) Old 07-31-2005, 07:55 PM Thread Starter
I did get the window back up by putting a hand on each side of the window and pulling it up manually. It just comes back down about 1/2 " after driving (due to bumps in the road and stuff).
Regards,
Bryan
post #6 of 14 (permalink) Old 07-31-2005, 08:32 PM Thread Starter
Hello again guys,
Do I need just the window regulator, or both the regulator and the motor? There is a regulator for sale on Ebay at $65US (list is supposedly about $115US) which isn't too bad.
Thanks,
Bryan
post #7 of 14 (permalink) Old 08-01-2005, 04:48 AM
W140Gill's Avatar
You will just need the regulator. It looks a bit like a bow. The regulators are side specific so you must make sure you buy the correct one.
W140Gill is offline
post #8 of 14 (permalink) Old 08-01-2005, 04:54 AM
W140Gill's Avatar
W140Gill - 7/30/2005 12:48 PM
It cost me about £60 from the dealer
W140Gill is offline
post #9 of 14 (permalink) Old 08-01-2005, 09:22 AM Thread Starter
Thanks again!
Would I need to buy the plastic gearing as well, or is that included with the regulator?
Here is the item I am looking at on Ebay:
7990393129
Thanks!
Bryan
post #10 of 14 (permalink) Old 08-01-2005, 11:38 AM
W140Gill's Avatar
bdonkersgoed - 7/30/2005 5:22 PM
Thanks again!
7990393129
Thanks!
Bryan
Everything you need is there. The gearing is housed in the centre section. The only thing you may need is are five 4.5mm pop rivets and a rivet gun.
W140Gill is offline
