Old 07-19-2005, 04:34 PM   #1 (permalink)
DMX
Date registered: Jul 2005
Send a message via MSN to DMX
is it possible to swap the rear lights model '91 into model '98
is it possible to swap the rear lights model '91 into model '98. I know the strip under the bootlid has to be replaced in order to get the facelift rear lights in. But is it possible to do so?
DMX is offline   Reply With Quote
Old 07-20-2005, 04:12 AM   #2 (permalink)
W140Gill's Avatar
Date registered: Jan 2003
Vehicle: W140 S class, E31 850Ci, E83 X3 3.0i Sport
RE: is it possible to swap the rear lights model '91 into model '98
yes, you must also file the corners of the trunk to be rounded.
W140Gill is offline   Reply With Quote
Old 07-20-2005, 04:38 AM   #3 (permalink)
DMX
ok thank you very much
Old 07-20-2005, 10:45 AM   #4 (permalink)
Date registered: Dec 2002
Vehicle: 92 500SEL -01 E320T
91? maybe a 92 140 chassis I think there were differences in the trunk liner and the innerpartof the tail lamp, along with the lower strip that also contained a infra red for the remote, the later models used a sensor on the mirror
Peter Guenther is offline   Reply With Quote
Old 07-21-2005, 02:46 AM   #5 (permalink)
W140Gill's Avatar
Peter Guenther - 7/18/2005 5:45 PM
There is a difference in the interior liner, however this doesn't effect the fitting of the newer style lamps. The centre lamp clear piece has a knock out if your car had a IR sensor there. It can be transplanted.
If anyone is upgrading the rear lamps, they must buy the whole lamp assembly (which includes the backing and bulb holders) and not just the lenses.
Old 07-21-2005, 04:27 PM   #6 (permalink)
DMX
So, to get this straight
I need :
- Rear lenses
- Rear Bulb holder
- Rear lower strip (white strip under the trunk)
correct?
Old 07-21-2005, 06:01 PM   #7 (permalink)
W140Gill's Avatar
DMX - 7/20/2005 11:27 PM
I need :
- Rear lenses
- Rear Bulb holder
correct?
yes.
Dont buy the lenses and the bulb holder separately. They can be purchased together cheaper. Just ask the vendor for the whole lamp assembly.
You will need..
1x right lamp assembly (all bulbs are included)
1x left lamp assembly (all bulbs are included)
1x centre lamp strip.
When you come to fit these, you must grind your trunk at the same time. Allow an hour for griding with a good metal file. Dont forget to paint the filed corners with the correct touch-up paint to avoid rust. This can be purchased from your mercedes dealer cheaply.
Old 07-22-2005, 03:30 AM   #8 (permalink)
DMX
thx alot, now, does anyone know where I can get the rear lenses cheaper than at the stealership? hehe
