Old 06-12-2005, 12:26 PM   #1 (permalink)
Date registered: Jun 2005
Vehicle: 1996 S320 Long Whl B
Power Antenna 1996 S320 Long: Need repl source
Please help with a used or otherwise less expensive replacement for my inoperable power antenna.
What does this antenna provide? FM? AM? Both? (I don't have a cell, or other radio transceiver.) Can I do without it?
Thank you.
Mac69 is offline   Reply With Quote
Old 06-13-2005, 07:14 AM   #2 (permalink)
Date registered: Jan 2005
RE: Power Antenna 1996 S320 Long: Need repl source
Hey Mac! I had the same problem with my S Class. Stupid me! I drove through a car wash with my eyes glued to the rearview mirror watching helplessly as broke off. Your best option, is to look on Ebay of course after I called the Dealer and was told it would cost $162.49!!! Type in: Mercedes Antenna and you should see a number of choices. I bought one with instructions for $15.00. Ask the seller where it's made and if it's an OEM product. The install is pretty easy, unless some of plastic line broke off inside the unit. In that case, you have to take the unit out which entails removing the rear quarter panel.(sucks in the Winter with frozen hands and insufficient tools!!) Take out the broken line, greese the gears, and re-attach the unit. Tricky part is turning back on the radio, then jumping out in time, as to feed to the new antenna line and lock it in place. Now it's good as new, bought it for cheap and installed it myself vs. paying the Dealer probably close to 200.00 to have them do it.
sclass4life is offline   Reply With Quote
Old 06-13-2005, 07:20 AM   #3 (permalink)
VenezuelaBenz's Avatar
Vehicle: 500S 1996
Send a message via MSN to VenezuelaBenz
http://www.autopartsheadquarters.com/epc-items.asp
Check this
VenzBenz
VenezuelaBenz is offline   Reply With Quote
