Old 06-05-2005, 08:00 AM   #1 (permalink)
VenezuelaBenz's Avatar
Vehicle: 500S 1996
Send a message via MSN to VenezuelaBenz
Cleaning Fuel Tank
Hello everyone,
My Pierburg pump on my S500 1996 just hit the bucket.
While waiting for the pump to arrive from the states ( I live in Venezuela and the pump here cost over $800.00 I found it for $189.00 on line http://www.autohausaz.com ) I took the old pump out and the filter ( it was full of brown gas it scared the hell out of me ) I decided to clean the gas tank.
At the bottom of the tank I took out the filter hose and the strainer which was broken and to my surprise the bottom of the tank was full of dirt. I recycled clean gas several times to get all the dirt out and now it seems to be clean. My question is Can I wash it also with water to put more pressure or is there any special stuff to clean the tank inside?
I think everyone should do that (clean the tank) every few years. I will try to attach a pic of the tank from alldata let see if it will work.
VenzBenz
VenezuelaBenz is offline   Reply With Quote
Old 06-05-2005, 05:31 PM   #2 (permalink)
Date registered: Mar 2004
Vehicle: 1997 S600 sedan
You could probably give it a good water wash.
You must make sure to thoroughly dry the tank afterward. I'd recommend rinsing with a water miscible organic solvent 3 or 4 times to help rinse all the water out of the tank. I'm thinking isopropyl alcohol, ethanol, methanol, or acetone. Then dry it completely by blowing air through it for a long time.
I'm not a mechanic, and I have no experience doing this. This is just what I would do if I were contemplating the same thing.
Brett
Brett San Diego is offline   Reply With Quote
Old 06-06-2005, 07:03 AM   #3 (permalink)
Vehicle: 500S 1996
RE: Cleaning Fuel Tank
Thank you Brett.
