Old 05-31-2005, 04:11 PM   #1 (permalink)
Mercedes_NY's Avatar
Date registered: May 2005
Vehicle: 92' 500 SEL
__.-~-.__ New Friend Has a Question __.-~-.__
HI GUYS ... I AM A NEW MEMBER AND I ALREADY HAVE A QUESTION AND HOPE THAT YOU WILL HELP ME ... I HAVE A 92' 500SEL ... THE MIRRORS SWITCH BROKE AND I PURCHASED A SUBSTITUE PART ONLINE ... COULD YOU TELL ME IN DETAILS WHAT TO DO IN ORDER TO CHANGE THE SWITCH SAFELY ... THANK YOU
HERE IS A PICTURE OF THE PART: https://www.autohausaz.com/secure/PartImages/1408206610.jpg
Mercedes_NY is offline   Reply With Quote
Old 05-31-2005, 05:20 PM   #2 (permalink)
bass1175's Avatar
Date registered: Feb 2005
Vehicle: 94 s420
RE: __.-~-.__ New Friend Has a Question __.-~-.__
Hey Ny, I never changed that switch however I removed the center console to change my shifter interior light. So here are the steps incase you need to remove the center console to gain access. Remove the ashtray using the side switch, then remove the wooden ashtray cover, I used a philips head from a drill set to get in there. using a torx wrench size 15 I believe, remove the two bolts on each side of the ashtray (inside). Then slide your hands in the ashtray port and push out the wooden console. You will have access to all the window switches Ect. The plastic trim around the knob just pops off. You may need to put the tranny in neutural or drive TO pull the console out. I think you need to do the same to access the wiring, here are the steps incase you do.
bass1175 is offline   Reply With Quote
Old 05-31-2005, 05:22 PM   #3 (permalink)
bass1175's Avatar
Vehicle: 94 s420
Old 05-31-2005, 06:04 PM   #4 (permalink)
AWESOME !!!
THANK YOU SO MUCH ...
Old 06-01-2005, 06:44 AM   #5 (permalink)
pcmaher's Avatar
Date registered: Jun 2004
Vehicle: 1995 S600 (sold)
DON'T overtighten screws (5)! That can break the bond between the mating inserts and the wood trim. If that happens, you will have a hell of a time trying to get those screws out in the future. Just snug them gently.
1995 S600, 1 of 618 (sold)
"Speed is just a question of money...how fast you wanna go?"
LONG LIVE THE W140!
Visit my Web Page at http://v12uberalles.com
pcmaher is offline   Reply With Quote
