» Sponsors
» Sponsors
Go Back   Benzworld.org - Mercedes-Benz Discussion Forum > Mercedes-Benz Sedan Forums > W140 S-Class
Old 09-08-2009, 08:17 AM   #141 (permalink)
MBs600v121998's Avatar
Date registered: Jul 2007
Vehicle: 1996 W140 S 600 L
So here we are finished from
Maj. assy M - Engine/
01-ENGINE HOUSING/
The 2nd item after the 01-ENGINE HOUSING/ is the 03-MOVING PARTS
Thanks God I own a Beautiful
German Silver (W140.057) S 600 L
Engine oil with filter 10,00 Litres
Engine oil specification MB 229.1/3/5
Power steering oil specification MB 236.3
Coolant 18,50 Litres
Cooling fluid specification MB 310.0, MB 325.0
Brake fluid when changing 1,30 Litres
Brake fluid specification MB 330.1, MB 331.0
Air-conditioning system refrigerant 1200 Gram
with air-conditioning system in the back 1400 Gram
Refrigerant specification R 134a
MBs600v121998 is offline   Reply With Quote
Old 09-08-2009, 08:26 AM   #142 (permalink)
So.
01-ENGINE HOUSING/
03-MOVING PARTS /
015 Crankshaft and flywheel
parts related
Note: there is no 02,
Old 09-08-2009, 10:06 AM   #143 (permalink)
030 Connection Rod and Pistons
Parts related
Old 09-08-2009, 10:45 AM   #144 (permalink)
01-ENGINE HOUSING/
03-MOVING PARTS /
05-TIMING/
030 Camshaft and Camshaft Adjuster
parts related
Old 09-08-2009, 10:54 AM   #145 (permalink)
045 Chain Drive
Parts related
Old 09-08-2009, 11:00 AM   #146 (permalink)
060 Valves
Parts related
Old 09-08-2009, 11:06 AM   #147 (permalink)
01-ENGINE HOUSING/
03-MOVING PARTS /
05-TIMING/
07 INJECTION SYSTEM
030 Air-Mass sensor, Throttle valve Actuator,(Used with LH-JETRONIC)
Parts same as the following post
Old 09-08-2009, 11:15 AM   #148 (permalink)
040 Air-Mass sensor, Throttle valve Actuator,(Used with MOTRONIC)
Parts related,
So the difference is MOTRONIC & LH-JETRONIC, so i guess i will make a separate post to ask about these differences
Old 09-08-2009, 11:19 AM   #149 (permalink)
090 Injection Valves, Fuel Distributor; used with (LH-JETRONIC)
Old 09-08-2009, 11:25 AM   #150 (permalink)
095 Injection Valves, Fuel Distributor; used with (MOTRONIC)
Parts related
