Old 11-28-2004, 01:24 PM   #1 (permalink)
~BANNED~
Date registered: Jul 2004
Vehicle: 98 S500
HOWTO: Replacing Cam Oil Line Fittings (Oil Guides) on the 119 (5.0L) V8
Unsure what forum this belongs. Hope this helps anyone who is considering replacement of oil guides/cam oil channels on the 119 motor
http://www.baxnet.net/merc/oilguides/story.htm
inetd is offline   Reply With Quote
Old 11-30-2004, 11:53 PM   #2 (permalink)
pchansen1's Avatar
Date registered: Sep 2004
Vehicle: 1997 S500
RE: HOWTO: Replacing Cam Oil Line Fittings (Oil Guides) on the 119 (5.0L) V8
Great article! I'm going to replace my valve cover gaskets very soon so I'll take a look at my oil guides at that time. Stupid question: I'm actually having difficulty identifying the oil guides. I believe theiy are the little black things that sit next to each valve pair (intake and exhaust). I can't see where the ones you identify as broken are broken. Also, you mention removing the cam braces to access the oil guides. It looks like the oil guides are next to and not under the guides. What am I missing?
Thanks!
Paul
PS - ALLDATADIY.com mentions removing fuel lines in order to remove the valve covers- did you have to do that or is there a work around?
pchansen1 is offline   Reply With Quote
Old 12-01-2004, 10:12 PM   #3 (permalink)
Date registered: Mar 2004
Vehicle: 1997 S600 sedan
Nice write up!!
Brett San Diego is offline   Reply With Quote
Old 12-02-2004, 10:01 AM   #4 (permalink)
Wow! That's the sort of article that makes this forum so valuable. Great work!!! Thank you for sharing!
Jim, Tulsa, OK (Member MBCA - Eastern Oklahoma Section)
'94 W140 - S420 (040 Black w/Black leather) "Xray"
'94 W129 - SL600 (Imperial Red w/Parchment leather) "Tucson"
'88 W124 - 300TE (Smoke Silver w/chocolate MBtex) "Hammer"
'84 W201 - 190D (Signal Red w/saddle tan MBtex) "Little Dark Red"
'98 Jeep - Wrangler SE (Moss Green w/medium gray vinyl) "Army"
Benz-Friend is offline   Reply With Quote
