» Site Navigation
» Other Sites
Old 11-14-2004, 03:02 PM   #1 (permalink)
Date registered: Aug 2004
Vehicle: 92 600SEL
CENTRAL LOCKING PUMP & CLOSING ASSIST PUMP INSTALL
I'm about to take delivery of each of these 2 pumps for my 92 600SEL - one in the trunk, one under the rear seat. Can anyone help with installation tips? Is it as straightforward as removing the old and plugging in the new, or is there other preparation/setting required? I'd be grateful for any help if you have undertaken this.
Dingo Dave is offline   Reply With Quote
Old 11-14-2004, 03:24 PM   #2 (permalink)
ronan95d2's Avatar
Date registered: Sep 2004
Vehicle: 95 s280
RE: CENTRAL LOCKING PUMP & CLOSING ASSIST PUMP INSTALL
Hi Dave,
Did you get the pumps from eBay in the end?? I've only replaced the central locking pump. Here are some pointers:
-Take a digital photo of the current installation before you start
-Use a small open ended wrench to prise the pneumatic connections from the old pump
-As you remove each connection from the old pump, connect the same fitting to the correct location on the new pump. It saves confusion later!
-There are 2 electrical connections. The smaller of the two lifts straight out. The larger one has a complex sliding mechanism which isn't at all intuitive. You need to slide the base of that connector horizontally to release.
Otherwise a piece of cake! Good luck.
Ronan
ronan95d2 is offline   Reply With Quote
Old 11-14-2004, 09:17 PM   #3 (permalink)
Date registered: Mar 2004
Vehicle: 1997 S600 sedan
Closing assist pump pics
See my earlier post.
http://www.mbnz.org/forums/forums/thread-view.asp?tid=1182970&posts=3&hl=closing+pump
Plug and play. Easy to swap out.
Brett
Brett San Diego is offline   Reply With Quote
Old 11-16-2004, 04:57 AM   #4 (permalink)
Date registered: Dec 2002
Vehicle: 92 500SEL -01 E320T
The only issue I have heard (other than buying someones defective pump) is that the newer replacement locking pump (under seat) is that you might need a fiting kit fot the hoses since the new one does not have the plate. The older one had a port for the back up rods also. To have both go bad is unusual, the culprit is usually the "close assist" the "locking, lumbar etc". does not fail that often.
Have you gone thru the fuse excercize?
Peter Guenther is offline   Reply With Quote
Old 11-16-2004, 05:24 AM   #5 (permalink)
Vehicle: 92 600SEL
Thank you gents for your input. Yes, Peter, I have been through the fuse exercise - pulling the fuse works only for a short period. Modification kit coming with ther cental locking pump. Fingers crossed! Will let you know once installed.
