Old 10-10-2004, 09:02 PM   #1 (permalink)
GR8CAR's Avatar
Date registered: Sep 2004
Vehicle: 1995 S600 Coupe
Send a message via AIM to GR8CAR Send a message via MSN to GR8CAR
Xeons for 95 600 Coupe
Does anyone have suggestions as to where I might look for a set of Xeon headlights for my 95 600 Coupe without having to go through a dealer? I understand they were available on S500 and 600's for model years 98 and 99.
Does anyone have any experience with this upgrade from the standard H4-type headlights?
Thanks!
GR8CAR is offline   Reply With Quote
Old 10-11-2004, 06:29 AM   #2 (permalink)
rbadina's Avatar
Date registered: May 2004
Vehicle: mercedes w124 260E
RE: Xeons for 95 600 Coupe
I have an identical S 500 coupe from 97 and i have instaled a xenon kit.you can look on www.EBAY.com
badlabel.com
rbadina is offline   Reply With Quote
Old 10-11-2004, 07:06 AM   #3 (permalink)
Vehicle: S320W
GR8CAR - 10/10/2004 11:02 PM
Thanks!
try www.xenondepot.com
the kit is very nice and comes with full instructions. the kit comes with original philips ballasts and philips 6000K bulbs.
I would look a hundred times before buying xenons off of ebay. Many sell cheap ballasts and blue painted bulbs.
Very big car, with a very small engine.
///S320 is offline   Reply With Quote
Old 10-12-2004, 10:52 AM   #4 (permalink)
GR8CAR's Avatar
Thanks rbadina and ///S320! I have looked on eBay and frankly, was not convinced with the solutions I saw. Primarily, I have been confused by how effective they really are since my headlamps use a double filament element (H4)for both high and low beams. For an effective Xeon set-up, I've been told that two separate light sources a necessary. Am I misinformed?
I'll check xenondepot...
Old 10-12-2004, 08:40 PM   #5 (permalink)
dtkw's Avatar
Date registered: Jun 2003
Vehicle: 86 560SEL
I have a xenon kit installed as well in my S500 coupe. I only installed the low beam setting. The low and high are well, a bit too complicated. So I just left the wiring and whats'not in the box. The low beam alone is bright enough IMO.
dtkw is offline   Reply With Quote
