I recently went to check coolant in tank and found a tan colored foam around the lip of the opening. I reached down in the tank and found a peanut butter color film on the inner top of the tank. I wiped out what I could but I still need to know what caused the gunk.
Vehicle: SEC 600 COUPE (RHD) One of the chosen few.
RE: Tan foam in coolant tank of 500SEL
Fred Berry - 10/10/2004 4:09 AM
Thank you
1992 500SEL
What colour is the rest of the water??.. was the engine hot? have you had any warning lights ? ???Possible indication of severe overheating -or-blown headgasket.. you need to run the engine and look to see if there are any bubbles appearing when warm.. geta tecky to look at it if in doubt..
If you've GOT to have a extension,
Have a BIG one.
