» Site Navigation » Other Sites
» Network Links
10-07-2004, 08:28 AM
#1 (permalink )
Date registered: May 2004
Vehicle: mercedes w124 260E
I`ve got some problems!!!! HELP
first i would like to salute you all because I`m new at this topic!
badlabel.com
10-07-2004, 09:05 PM
#2 (permalink )
Date registered: Sep 2004
Vehicle: 1995 S600/2000 ML430
RE: I`ve got some problems!!!! HELP
I agree. Now, what are those problems?
10-07-2004, 10:24 PM
#3 (permalink )
Date registered: Apr 2004
the problem is that he forgot to post the problem.
10-11-2004, 04:38 AM
#4 (permalink )
the ASR light is on, the gearbox doesen`t shift gears smooth like before, the ABS stoped working and the cruise controlas well,all this since the light is on. I realy need some help because like this car and is bad that i can`t fix it
thanks!!!
10-11-2004, 04:57 AM
#5 (permalink )
a problem indeed.
the fuse are okay? including the one on base module?
the brake light switch is okay? reset it and try.
usual problem, throttle valve actuator, throttle valve actuator wiring, and the ASR control unit.
10-12-2004, 04:14 AM
#6 (permalink )
well the fuses are ok. all of them checked.the problem is that all this malfuncion appeared when the ASR light turned on.I tooked the benz to the local dealer but they haven`t found anything bad at the engine compartiment.do you think that the throtle actuator is the answer.
10-12-2004, 06:42 AM
#7 (permalink )
Date registered: Dec 2003
did they plug in a computer - and read the error codes? it is highly unlikely that the light will be on and no code to be stored.
also check the ABS sensors on all the wheels, if they break (with a stone for example) all the above will show up.
10-12-2004, 11:33 PM
#8 (permalink )
Date registered: Mar 2004
Vehicle: 1997 S600 sedan
I like the suggestion to check ABS sensors.
10-15-2004, 02:36 AM
#9 (permalink )
The problem is that i`ve been to the local dealer and after a check up we didn`t find anything wrong. So i realy don`t know what to.
12-05-2004, 04:54 PM
#10 (permalink )
hello any one ???? I still haven`t fix the problem. can you give me hand cause the winter is coming and i`m in deep shit[V]
Thread Tools Display Modes Linear Mode
