Old 10-06-2004, 08:04 AM   #1 (permalink)
Date registered: Oct 2004
Vehicle: 99 SL500 92 300SE
Oil filter cap
I have my 300se for over 13 years and trying to replace oil first time by myself.
I can not turn oil filter cap to losen using professional cap tool which has good grip. I believe this cap is closed without tool so that cap should be easily open with tool.
Is there any special trick to open this cap ?
land747 is offline   Reply With Quote
Old 10-06-2004, 11:19 AM   #2 (permalink)
Merc600sec's Avatar
Date registered: Mar 2004
Vehicle: SEC 600 COUPE (RHD) One of the chosen few.
Send a message via MSN to Merc600sec Send a message via Yahoo to Merc600sec
RE: Oil filter cap
If it is the black plastic cap on the left side of the engine.. i pour freshly boiled water on to it then use the removal tool..Do not try and use a strap remover you may break the cap..
If you've GOT to have a extension,
Have a BIG one.
Torque isn't cheap
Merc600sec is offline   Reply With Quote
Old 10-09-2004, 08:27 AM   #3 (permalink)
RE: Oil filter cap
Thank you Merc600sec. But my 300se
has filter location behind airfilter and it is alminum.
I tried to turn with big wrench but no chance to turn it is solid locked. I feel I may break alminum case holding filter. It is shaped like horn from lower engine block.
I can not believe cap locked this hard without using tool.
Any suggestion ?
