Old 10-04-2004, 12:06 AM   #1 (permalink)
Rainmaker's Avatar
Date registered: Aug 2003
Vehicle: BMW E36, MB W140
Ignition Coil - where to measure Resistance?
Hi does anybody know where to measure the resistance on the Ignition Coil?
I got a new coil, but I could not get any resistance reading no matter where I stuck the multimeter.
Background, my "cylinder #5 misfire" problem returned, and now it seems to happen almost every day!. So I got a new coil, and would like to measure the resistance difference between the old vs new to determine if its the coil could be the cause. I've already changed the plugs and the wires.
Thanks!
Rainmaker
Rainmaker is offline   Reply With Quote
Old 10-04-2004, 07:04 PM   #2 (permalink)
chuckindetroit's Avatar
Date registered: Jun 2003
Vehicle: 1986 560SEL, 1986 560SEL, 1992 500SEL
RE: Ignition Coil - where to measure Resistance?
There should be no electrical connection between ground (the body or frame of the coil) and any other terminal. If there is the coil has an internal short to the frame and is bad. There should be a low resistance connection between two of the low voltage connection points in the cable harness connection point and a much higher (Kohms) reading between either of these two points and the high voltage towers. I have not had the need to probe the coil on my 500 SEL but this is a general guide to ignition coils as on my older 560 SELs. The low voltage windings which are connected to the ignition system are connected internally in the coil to the high voltage windings which have a much higher resistance due to the greater number of turns and finer diameter wires.
chuckindetroit is offline   Reply With Quote
Old 10-04-2004, 08:16 PM   #3 (permalink)
Date registered: Oct 2003
Vehicle: 00 S500,99 4wgn,87TD
if these coils are internally bad, 2 cylinders will fail, not 1. if wires and boots are new, i would look into injector or wire harness.
BENZDOC is offline   Reply With Quote
Old 10-04-2004, 09:36 PM   #4 (permalink)
sleepwalker's Avatar
Date registered: Apr 2004
Send a message via ICQ to sleepwalker Send a message via MSN to sleepwalker Send a message via Yahoo to sleepwalker
you can't.
testing of the ignition coil on your model can only be done using oscilloscope, with the engine at idle speed.
sleepwalker is offline   Reply With Quote
Old 10-26-2004, 11:56 PM   #5 (permalink)
Rainmaker's Avatar
Coil fixed misfire problem!
Everyone thanks for the info!
Just to followup, I put in the new coil, and the Cylinder 5 doesn't misfire anymore! Its been good for 2 weeks so far, and I floor the gas whenever I have a chance, and the engine never misfires anymore.
Now, does anyone know if coils "age" or have performace degrade over time? I am considering replacing the 2 other coils, since they are as old as the one that failed. These 2 original coils work fine right now, but I am not sure if they will fail soon, and also don't know if aging coils might cause performance loss?
Thanks,
Derek
Old 10-27-2004, 11:34 PM   #6 (permalink)
Date registered: Mar 2004
Vehicle: 1997 S600 sedan
Good to hear. I can't answer your question, but if the cost isn't huge,
I'd replace them. I just like new stuff.
Brett
Brett San Diego is offline   Reply With Quote
