Old 10-03-2004, 10:12 AM   #1 (permalink)
wildponey's Avatar
Date registered: Sep 2004
Vehicle: 1994 S420
Reverse antena sensors-won't go down!
My reverse antena sensors will not go down into place. I have checked them and don't seem to understand why. They were working before but from one day to another they justed stayed up. If any one can give some info. on how to solve the problem, it is "GREATLY" appreciated.
"Big Body Benz"...got to have 1 !
wildponey is offline   Reply With Quote
Old 10-03-2004, 04:22 PM   #2 (permalink)
wildponey's Avatar
Vehicle: 1994 S420
RE: Reverse antena sensors-won't go down!
Now i cant even open my trunk....man what a mess!
I have a 94 S420.
Old 10-03-2004, 05:53 PM   #3 (permalink)
Date registered: Dec 2002
Vehicle: 92 500SEL -01 E320T
The pump that controls those is under ther the passenger rear seat, pray, pull the fuses and hope it is reettable if not is the pump, few hundred like 5
this pump controls the rods , lumbare, ac assist, and some headrests, plus locking, Do a search
Peter Guenther is online now   Reply With Quote
Old 10-04-2004, 04:16 PM   #4 (permalink)
Peter Guenther - 10/3/2004 7:53 PM
I have a 94 S and on my car the backup antennas are electric.There has to be some switch that activates them when you put the car in reverse. check around transmission and at antennas themselves.
Try using your key to open trunk
Rdanz is offline   Reply With Quote
Old 10-05-2004, 08:31 AM   #5 (permalink)
loveit_hateit's Avatar
Date registered: May 2004
Vehicle: '95 S320
I recently did some trouble-shooting on my vacuum system and I can tell you the backup rods, gas door lock, trunk release, trunk lid handle, lumbar, door locks were all controlled via the pump. To raise the backup rods, the pump has to blow pressure to the rods. To lower the rods, the pump has to create vacuum by sucking the rods back down. If you have a leak in the system, it will prevent different items from functioning. In my case, the trunk lid handle wasn't extending when the trunk was open. I could hear a whinning noise for about 10 - 20 seconds after the trunk was opened that was the pump trying to push the lid handle out. After a period of time, the pump circuit gives up if it can't perform the action. It turned out that the gas door lock diaphram had developed a leak. I replaced the diaphram and it solved my problem.
Your problem may be a faulty part in the system (maybe even the pump) or a leaking, loose, or disconnected hose. If other things like the door locks and lumbar still work, then it is probably not the pump but another part in the system.
loveit_hateit is offline   Reply With Quote
Old 10-06-2004, 04:34 AM   #6 (permalink)
sleepwalker's Avatar
Date registered: Apr 2004
Send a message via ICQ to sleepwalker Send a message via MSN to sleepwalker Send a message via Yahoo to sleepwalker
there's no such thing.
all are pneumatic.
sleepwalker is offline   Reply With Quote
Old 10-06-2004, 07:04 PM   #7 (permalink)
wildponey's Avatar
Vehicle: 1994 S420
Thankx to all of you, you have been much help. I took the car in to a place here called mbz motors, all they do is work on mercedes, they checked out the problem and it it definetly the pump that is located under the rear passanger seat. Just so you guys will know if one day your pump gose out it's $ 700.00 just for the fu@#n pump......oh well....again thankx for the info....much help
Old 10-06-2004, 07:12 PM   #8 (permalink)
fact is:
it was just the motor carbon brush inside the pump that's worn out.
Old 10-10-2004, 08:11 AM   #9 (permalink)
Vehicle: e320
Wildponey:
Have you discarded the old unit? I'm looking for internal parts and was wondering if you were interested in shipping it to me?
Ron
tower is offline   Reply With Quote
Old 10-11-2004, 11:00 PM   #10 (permalink)
wildponey's Avatar
Vehicle: 1994 S420
so sorry, today was trash day and you know the rest of the story........it's gone!........well thankx for asking[:(]
