I have a 98 S600 and the cell phone antenna is always up. The dealer said that most likely someone plugged in a cell phone, then pulled it out without turning it off, so the antenna is stuck in the extended position.
Does anyone know of a way to lower the antenna? Is there some way to short pins 1&2 or something that will cause the antenna to lower?
Vehicle: SEC 600 COUPE (RHD) One of the chosen few.
RE: Lowering Cell Antenna
Some pics might help us to help you..
What sort of cellphone was fitted ..
do you have the splitter box in the trunk?
do you have a normal radio antenna as well..
Does that work normaly..
If you've GOT to have a extension,
Have a BIG one.
I would check power to the antenna, or the motor is defective. If the ignition is turned off the antenna retracts. You can always open it up retract it and disconnect the power
