Old 09-30-2004, 02:29 AM   #1 (permalink)
maci911's Avatar
Date registered: Sep 2004
Vehicle: 94S420,98S320,95740I
cup holders,trunk release button,console button with tire picture
i bought an S420 1994 a week ago looked everywere and cant find the cup holder please help also is there a trunk release button on the console and also there is a button on the console that has a tire picture on it that lights red when u put it on. thanks in advance
maci911 is offline   Reply With Quote
Old 09-30-2004, 11:43 AM   #2 (permalink)
Merc600sec's Avatar
Date registered: Mar 2004
Vehicle: SEC 600 COUPE (RHD) One of the chosen few.
Send a message via MSN to Merc600sec Send a message via Yahoo to Merc600sec
RE: cup holders,trunk release button,console button with tire picture
There is no CUP holder.. for the driver, There is one for the passenger in the glove box.. The RED light on the switch with the tyre on is your traction control telling you its working..The central locking will not open the trunk for you.. you have to do that yourself..Welcome to the land of Mercedes..Enjoy your stay...
If you've GOT to have a extension,
Have a BIG one.
Torque isn't cheap
Merc600sec is offline   Reply With Quote
Old 10-04-2004, 05:01 PM   #3 (permalink)
S500L's Avatar
Date registered: Aug 2003
Vehicle: S 500 L
The cupholder for passenger only is located at the back of the glovebox compartment. Open the glovebox and lift the cover that is attached to the back of the door.
The button with the tire picture is your traction control switch. If you press it and a red light lights up, it tells yout the system is OFF ! Press the switch again to turn it on (the red light should go off). An orange triangle on your speedometer will tell you when the system is operational. If the triangle is lighted constantly, it remainds yout that the system is either off or there is a malfunction.
U.S. market W140s had a trunk opening switch on the central console which was later (I think after 1997) standarized on the rest of the world to open the trunk from the inside. Although, I believe this system was first fitted in the U.S. on 1995 models. You may have a very late 1994 with this feature installed.
A. R. R.
S 500 L, 1998
E 320 T, 1995
S500L is offline   Reply With Quote
