Old 09-29-2004, 11:53 AM   #1 (permalink)
Date registered: Aug 2003
Vehicle: 1998 S420
SQUEAKY BLOWER MOTOR
On my 98 s420 when I turn on my a/c and adjust speed of the blow, the motor begins squeaking. Sometimes it stops and start and again especialy when I hit a bump. I was thinking the blower motor is going bad.
HMCGARY is offline   Reply With Quote
Old 09-29-2004, 12:49 PM   #2 (permalink)
Merc600sec's Avatar
Date registered: Mar 2004
Vehicle: SEC 600 COUPE (RHD) One of the chosen few.
Send a message via MSN to Merc600sec Send a message via Yahoo to Merc600sec
BLOWER MOTOR
Yup the bearings are quite easy to get at, I have some picks in my gallery from when I changed my pollen filter might help you
If you've GOT to have a extension,
Have a BIG one.
Torque isn't cheap
Merc600sec is offline   Reply With Quote
Old 09-29-2004, 01:47 PM   #3 (permalink)
Vehicle: 1998 S420
RE: BLOWER MOTOR
How easy is it to replace bearings and where could I purchase them?[:)]
Thanks
Old 09-29-2004, 08:46 PM   #4 (permalink)
Date registered: Oct 2003
Vehicle: 00 S500,99 4wgn,87TD
RE: SQUEAKY BLOWER MOTOR
you can't buy the bushings. oil the top and bottom one and take a soda bottle cap, run a small bead of silicone sealant around the edge. place it down over the top bushing. this makes a great "umbrella". the water that caused the bushing to start locking is from the drains of the inlet distributor being clogged. the inlet distributor is the cover that you removed to access the filter. the drains hoses are clogged or crimped due to improper installation. "clean the cause"... ps. the locking blower will cause the blower module to run even hotter than it normally does. not a good thing...
BENZDOC is offline   Reply With Quote
Old 09-30-2004, 08:08 PM   #5 (permalink)
chuckindetroit's Avatar
Date registered: Jun 2003
Vehicle: 1986 560SEL, 1986 560SEL, 1992 500SEL
I have looked into replacing the bushings with bearings and have found some compatible sizes but just don't have the time. So I just ordered a replacement blower motor today from Benzbin. Total with shipping is about $165. Here is a link to some bearings.
http://www.vxb.com/miva/merchant.mv
chuckindetroit is online now   Reply With Quote
Old 09-30-2004, 10:02 PM   #6 (permalink)
Vehicle: 1998 S420
Let me know how the installation go.
