Old 09-27-2004, 03:06 PM   #1 (permalink)
AL-Sayegh's Avatar
Date registered: Feb 2004
Center Counsel
Hi, can some one help me in how to remove the center counsel for my S320 1995 . The switch is broken and I tried to pull it out but I couldn’t . I don’t know where to start ?!!!! Thanks
[img]http://[/img]
AL-Sayegh is offline   Reply With Quote
Old 09-27-2004, 07:23 PM   #2 (permalink)
Date registered: Oct 2003
Vehicle: 00 S500,99 4wgn,87TD
RE: Center Counsel
is the wood 2 separate pieces? (split below ash tray) if you are trying to put the mirror switch back in, it can be done real simple. remove the rectangular trim around shifter. insert a bent 90 degree steel rod into the left upper corner, (one end has to be 2 inches long) turn rod so it goes under the mirror switch and pull it up. if the clips are not broken, it will snap back in.
BENZDOC is offline   Reply With Quote
Old 09-28-2004, 03:51 AM   #3 (permalink)
sleepwalker's Avatar
Date registered: Apr 2004
Send a message via ICQ to sleepwalker Send a message via MSN to sleepwalker Send a message via Yahoo to sleepwalker
RE: Center Counsel
first remove the radio.
sleepwalker is offline   Reply With Quote
