Old 08-18-2004, 03:20 PM   #1 (permalink)
Date registered: Jul 2004
Flasher not working!
Hi all,
I just discovered that the flasher doesn't work on my 97 S320! The high beam works fine when you push the stalk away, but when you pull it towards you, it doesnt flash!!
Any ideas???
Thanks!!
frog1520 is offline   Reply With Quote
Old 08-18-2004, 04:23 PM   #2 (permalink)
Merc600sec's Avatar
Date registered: Mar 2004
Vehicle: SEC 600 COUPE (RHD) One of the chosen few.
Send a message via MSN to Merc600sec Send a message via Yahoo to Merc600sec
RE: Flasher not working!
Relay -- try that first..
If you've GOT to have a extension,
Have a BIG one.
Torque isn't cheap
Merc600sec is offline   Reply With Quote
Old 08-18-2004, 04:46 PM   #3 (permalink)
Cheers mate, will do!
Old 08-18-2004, 08:16 PM   #4 (permalink)
Date registered: May 2004
Which relay merc600?
merc man is offline   Reply With Quote
Old 08-18-2004, 09:40 PM   #5 (permalink)
pcmaher's Avatar
Date registered: Jun 2004
Vehicle: 1995 S600 (sold)
I have the same problem. I played around with the stalk, and after pulling it towards me several hundred times[:)], I got the high beams to flash. It promptly stopped working again the next day. I'm guessing that the contacts in the combination switch are crudded up or something. Someday I'll fix it, but I wonder if should bother...too many left lane morons in the US don't know what flashing high beams mean anyway[xx(].
1995 S600, 1 of 618 (sold)
"Speed is just a question of money...how fast you wanna go?"
LONG LIVE THE W140!
Visit my Web Page at http://v12uberalles.com
pcmaher is offline   Reply With Quote
Old 08-19-2004, 05:17 AM   #6 (permalink)
Hi chaps,
Which relay is a good question!! And where is it!
I thought it would be in the fuse box. Checked the fuse and thats OK... the same fuse (15 in my box) controls other stuff (radio etc) too which is working fine!
Thanks again! [:D]
Old 08-19-2004, 05:52 AM   #7 (permalink)
lnguyenh's Avatar
Date registered: Jan 2004
Vehicle: SL500, S420
pcmaher - 8/18/2004 11:40 PM
Totally! [:P]
lnguyenh is offline   Reply With Quote
Old 08-19-2004, 03:12 PM   #8 (permalink)
Date registered: Feb 2004
I have the same problem on my 94' S420 and also want to find out if there is an easy way to solve it. I checked fuse this morning, it is OK. But I don't know where the relay is. Plus, I heard the cover under steering can be opened to check connection of wiring. But don't know how. If someone can post instruction or pictures to help us to solve this headache will be great.
mbs420 is offline   Reply With Quote
Old 08-20-2004, 12:13 PM   #9 (permalink)
mercS600's Avatar
Date registered: Nov 2003
Vehicle: S600L
At the rear of the large fuse box in the engine bay there are a few relays.The one you want is labelled N10.This is the one for turn/hazard signal,heated rear window and wiper motor.I have had 3 w140's and this relay has had to be changed on all of them!It only affects the indicators though?!!!!Strange.[:0]
mercS600 is offline   Reply With Quote
Old 08-20-2004, 12:19 PM   #10 (permalink)
mercS600's Avatar
Vehicle: S600L
Sorry i misstook flasher as meaning turn signal/indicator!I will have a look on ALLDATA for you.[:)]
