Prior to 95, remove ash tray, loosen coverscrew, slide up and remove, look down into opening, two lateral "torx screws" holding both panels together, remove screws with right angle torx.
Remove trim around shift lever by gently prying up, with a non scratching tool. Pull up panel and forward from ashtray side, rear has "u" shaped catch that is holding into console. The switches are attached and you can go from there. If you break those "u" s you will hate yourself, since they are part of the frame that holds the switches. The frame is hot glued and stapled to the panel, there are some still available, otherwise $$$ panel.
In looking at the CD it appears the panel is one piece rather the previous two piece, and has to be released at the arm rest compartment side and then pivots up at the dash.
