Old 08-14-2004, 11:06 AM   #1 (permalink)
Date registered: Dec 2003
Vehicle: 1998 S500
Benzdoc...opinion needed on (ABS\BAS-ASR)
Benzdoc,
It happen while on a normal driving,Just brakes and the ABS & BAS\ASR light came on. When to a Mechanic and diganosed (1 Brake lamp switch fault)(Bas Can Bus valve error) we change new brake lamp switch,not the Bas Can Bus valve.Both light went off. After driving for a day both lights came back on. Please help.... thanks.
Tony.
Classic_wong118 is offline   Reply With Quote
Old 08-14-2004, 08:05 PM   #2 (permalink)
Date registered: Oct 2003
Vehicle: 00 S500,99 4wgn,87TD
RE: Benzdoc...opinion needed on (ABS\BAS-ASR)
tony, this is one of those fixes that will take some patience. all of the stored codes must be logged then cleared or removed from all systems. not just abs, but engine, transmission, bas,asr, the base module, ect... you say you changed the brake light switch, replaced with an original? (not that they are any good!!) was it installed with the pedal depressed and the switch fully extended so that when the pedal is released it set the depth?? were all codes removed? hope so.. be real sure that the charging system is ok and the battery is fine. erratic voltage is a major problem.. i'd love to help you but i need more info....kevin
BENZDOC is offline   Reply With Quote
Old 07-11-2005, 05:32 PM   #3 (permalink)
Date registered: Jul 2005
Send a message via AIM to BenzS500InVa
RE: Benzdoc...opinion needed on (ASR- ABS)
Benzdoc,
It happen while on a normal driving, on my 1995 S500 coupe. I start the car second time. Two yellow lights came ON at the same time ASR & ABS. both of them are yellow and next to each other. I felt like there no power steering and the steering wheel felt heavy when I make a turn . I check the brake oil and power steering oil they and all the fuses they all fine. I also took out the BATTERY cables for a day so it can reset it self, but that also didn't help:(. Please help.... Thanks.
Alex
BenzS500InVa is offline   Reply With Quote
