Old 08-06-2004, 01:39 PM   #1 (permalink)
Date registered: Jul 2004
Send a message via AIM to 96S320.
oil pressure question
I have a 96 S320 and the oil pressure gauge on my dashboard stays right above 0 at idle, and only goes up a to about the 1 when accelerating. I was wondering if this is normal or not??
96S320. is offline   Reply With Quote
Old 08-06-2004, 01:51 PM   #2 (permalink)
barry putnam's Avatar
Date registered: May 2003
Vehicle: 1995 MB S320V: 2006 kawasaki vulcan 900 lt
RE: oil pressure question
seems low, mine idles at 1 and runs at 3.
Barry
BECAUSE SIZE REALY DOES MATTER, W140
barry putnam is offline   Reply With Quote
Old 08-06-2004, 02:40 PM   #3 (permalink)
pcmaher's Avatar
Date registered: Jun 2004
Vehicle: 1995 S600 (sold)
As long as you never see "0", it means you have at least some pressure. ZERO is bad. Considering this is a MB and not a Ford, it's not normal. I would invest in a new oil pressure sender as a first step. These can go bad after time and provide false readings.
1995 S600, 1 of 618 (sold)
"Speed is just a question of money...how fast you wanna go?"
LONG LIVE THE W140!
Visit my Web Page at http://v12uberalles.com
pcmaher is offline   Reply With Quote
Old 08-06-2004, 07:02 PM   #4 (permalink)
S500L's Avatar
Date registered: Aug 2003
Vehicle: S 500 L
If you use a very thin synthetic oil (like Mobil 1 5W15) your oil pressure readings will be lower than usual.
If you are using the specified regular oils, then the readings seem a little low. Checke the oil pressure sender as recommended above.
A. R. R.
S 500 L, 1998
E 320 T, 1995
S500L is offline   Reply With Quote
Old 08-07-2004, 07:28 PM   #5 (permalink)
I just did a oil change and the reading now stays at the 1 - I will first replace the oil pressure sender as you recommend. Thanks
Old 08-07-2004, 07:37 PM   #6 (permalink)
Where can I pick up a oil pressure sender? I dont want to pay dealer prices.
Old 08-09-2004, 06:05 AM   #7 (permalink)
pcmaher's Avatar
Try Phil at Fast Lane. He's very helpful, and has good prices.
Toll Free 1-888-333-4642 or philip@mercedesshop.com
Old 08-10-2004, 01:27 PM   #8 (permalink)
Where is this part located and how hard is it to change myself??
Old 08-10-2004, 03:04 PM   #9 (permalink)
pcmaher's Avatar
Don't know...not familiar with six's. Try Phil. He may have a diagram to share with you. I would suggest subscribing to Alldata.com. They have a lot of info for W140's. I've been happy with their info.
